I know the factory bulb is a 9012, however, I read that you can use a 9006 bulb in that socket with no problem since the wattage/ base is the same. Apparently if you use a 9012 in a 9006 base you have to trim the tab but not the other way around. Anyone have thoughts or suggestions on using this kit? I'm not very technical or mechanical. I did change out all my interior LEDs with a kit from Amazon...fantastic bulbs. Super bright. I replaced all my exterior bulbs with LEDs from superbrightleds.com ...great products. I do have the hyper flash issue which I'm trying to figure out how to resolve. I do have a set of resistors but I'm not good with wiring so I'm watching YouTube.
https://www.superbrightleds.com/cat/led-headlight-bulbs-conversion-kits/filter/Cross_Reference_Number,9006,21,7821:
