Joshua Sharp
Facebook Member-
Everything posted by Joshua Sharp
thin fiber board and wrapped in vinyl
the edge is done !!! i will still do things to her to add extra pop to the ride but she is done and here are all my pictures from SBN 2014 SUB BOX !!! seat trim panels and pics of the car and engine bay Hope you guys enjoy the car and cant wait to show when else i do to her.
what price are you looking to get for them? and i would be willing to trade the wheels i have now plus cash, one rim has rubbed a curb tho so it has a little blemish :-(
if these are stil available in a few weeks i will take them off your hands most likely !
ok so im trying to figure this out and i cant seem to figure it out ... i have a 50A astron power supply that i use for my capri and will start using on my edge ... with the capri everything works good ... the edge ... not so much before you think i have already checked and re checked all the wiring and nothing is crossed, messed up, or wrong. when i plug the astron up to the edge ( which is wired in the back of the car with a 50A plug that goes into the distro blocks which then goes directly into the battery terminals up front. when the car is off the astron does nothing ... the amp meter does not move ... now the minute you turn the key to the acc. position ... it pegs the astron and maxes out the amp meter WAY past the 50amp mark ... im thinking it has something to do with the computer but i dont see how when what would happen if i wanted to jump start the car ... the jumping car would be 14V which the astron is set at and you turn the key on to start car ... Just really confused about it and trying to figure it out.
subs will be 2 Linear Power ISO-KIT 8" subwoofers. in a custom ported box tuned to 24hz
alot easier to mount the tweeters on the dash because its alot easier to aim them at the driver and you are able to mount the tweeters deeper on the dash for better stage depth. The seats were actuall quite easy to strip and put back together ... all clips and zippers
To tune the processor you have to hook the processor up to the computer to use the software so this is a video of how i modded the car to accept the computer. i was supprised to see that in that component ford actually used good audio grade caps in the circuitry.
i know this is in the power train section ... if possible could a mod move this to the appropriate location
running the audio wire from the radio to to processor running the speaker wire to the door speakers ran the wire for the amps and all done the seats will still function and lastly from what i have so far are the tweeters placed upon the dash i will post some more pictures if i come across some that i missed ... Details of the system the speakers are Blues Car Audio 6.5" active components set Blues Car Audio is owned by Linear Power The 6.5" door speakers are on a Linear Power 2150, The Tweeters are on a Linear Power 2150 and the two subs will be on the Linear Power 2250.
was finally able to use my second battery posts those zip ties have since been changed to black. the audio processor for the car a Helix DSP
the seats ! test fit FINISHED and mounted !!! Once the trim panels are added there will be a second pattern that will place over them so that when the seats are folded down no carge space is lost you can still put large cargo over the amps if needed. Running the Power and Ground for the amps is next.
ill leave the chit chat out and just post all the pics i have :-) wrapped the battery to help keep engine heat off it added some lighted door sills and changed color to blue to match the blue puddle lamps more deadener on the door itself old vs new of the front door speakers how i mounted the door speakers Here are the Amps that are going to be going into the car ... Two Linear Power 2150s and One Linear Power 2250 Where am i going to put these beautiful amps you ask? Well here is part of the car you will recognize
just a little background of me ... i am into car audio mainly the sound quality aspect and i compete in sound quality. So the main bulk of what i have done to the edge is for sound system. I started off a while back putting sound deadener throughout the whole car 160 square feet to be exact of Second skin audio damplifier pro. I dont have many photos of the finished product but every part of the car is covered and the doors have 2 layers
ok so i am going to turn this into a full list of mods thread that i have done to my edge and still working on ... i have alot of pictures to add and i need to get back into this forum instead of being a troll. First off thanks for the kind words and compliments to wanabang the positive terminal worked out great but the ground one was a booger to get tight.
best Dash carpet !!
Joshua Sharp replied to Joshua Sharp's topic in Interior, A.C., Heat, Interior Trim
those will not help with tweeter reflection -
best Dash carpet !!
this is going to be a competition sound quality car and the carpet will help on the dash to prevent tweeter reflection off of the dash ... you just want the sound to reflect off of the windshield ... when you have the sound reflecting off of the windshield and then the dash it can throw off the staging and positioning. the use of a towel is common but i will be competing not only in sound quality but install as well so i would like it to look better than just a towel -
ok im looking to find the best fitting best looking dash cover for a 2012 ford edge ... the cover needs to be carpet or some sort of soft plush cloth ... mainly carpet !! let me know thank you very much !!!
ok ... so i got the lighted door sills for my 2012 edge with the ford instructions and i wired the power up to the wire on the plug it told to and the mic quit working .... disconnected the lighted door sills .... mic works ... soooo ... i remember reading somewhere there is a different wire in the sill that i can connect to? or what wire do i connect to ? the door sills did delay the most before they turned off and they stay on constant when the car was running... but what wire do i connect the power to because i obvuously messed up because the mic does not work when the lighted door sills are hooked up to the wire that i connected them to ... :-/ help me !!
got the fuse panel cover done and in the car !! the next thing to do is the air cleaner box base coat ! added pop!! the lightning bolt is yellow and the i in the book is yellow !!! it looks superb
