DBEDGE23
Everything posted by DBEDGE23
X-Pipe - No Resonator - MRT Exhaust
DBEDGE23 replied to DBEDGE23's topic in Accessories & Modifications
This post is way over due.... Click the links below for Idle and a video of some revs to about 3000-4000 rpm. Again this is true dual exhaust with X-pipe, no resonator of course and into MRT mufflers. I love the Turbo spool sound!!! Enjoy. Feel free to ask any questions about the install. But is pretty straight forward. Idle sound - https://1drv.ms/v/s!AhZyi6BJtW7Vjv0pGMwwqDtVP_emfg?e=5UmPQR Revs (Turn up your speakers and you can hear the turbos - LOL) - https://1drv.ms/v/s!AhZyi6BJtW7Vjv0oE1mcu8EFNK5mpg?e=jaLtTa -
From the album: Pics to Post
Another satisfied customer.... LOL! This fits nice and snug on my 2015 Ford Edge Sport FWD.
That is great to hear! Lookin forward to the next update!
Has anyone thought about or attempted to modify this CAI to work with the 2.7L Twin Turbo? K&N is suggesting that on the 3.5L version it will pick up 15.3 HP @ 5802 RPM & 13.1 lbft @ 3498 RPM Performance Air Intake System (knfilters.com) - 2015-2018 EDGE 3.5L I know we have had many attempts at CAIs and was wondering if this one has been tried! Thanks!
Keep the good work! We are here to help!
Coming Soon! I'm finishing up my build. I should have some more pictures and descriptions as the weather gets warmer.
I just PM'd you XTRA - Count me in.
Hey everyone! 2015 Ford Edge Sport 2.7 TT - Just some quick pictures of my new exhaust midsection. X Pipe - into MRT mufflers that were already installed. Let me tell you no need to run any resonator with MRT mufflers. It sounds like someone open up the valves on a valvetronic exhaust. You can really hear what the MRT mufflers are suppose to sound like. Taking off from a stop is awesome with a nice deep tone. Sound clips - Idle-Rev-drive by are coming....Thanks!!
Thanks for that offer. I live in Tennessee. 2015 Ford Edge Sport 2.7L FWD. I have attached a picture of my MRT Axle Back exhaust. Since I don't have AWD the pipes are closer together by the rear axle.
So this is what I got back from Zury when I asked him about making the cat back section: Good morning, so we do everything custom to the car. We wouldn’t be able to produce and ship. If you are located close we can definitely do the this section but would need the vehicle. It wouldn’t require getting the downpipes/hiflo cats as well. I’m not too familiar with MRT exhausts, but whatever we make would be able to mate to current setup. If you have any further questions give us a call or text at 4435173810 Those were resonators provided by the customer. Which sucks because I would love to have this section.
So what is the price of this section and how do we order it? This is the Cat Back section correct? I assume it will bolt up to the stock Cats section/down-pipes? I bet this would sound awesome with the MRT Axle Back mufflers.
No, rookie mistake. My wrench touch the positive side of the battery fuse block while taking off the negative side. I had the rubber boot off due to the install. I found the issue with the dash lights. When installing DaytimeBrightlights DRL I put the fuse back in slot 91 instead of 92. Everything is fine now. Thanks, DBEDGE23
I found the issue. When installing DaytimeBrightlights DRL I put the fuse back in slot 91 instead of 92. Everything is fine now. Thanks!
Installed new DRLs from daytime but my fuse circuit/block on the positive battery side blew and I had to get a replacement. Battery was disconnected for a couple days while the new part was ordered. Everything was hooked back up and functioning fine but when I started the car I now have three lights on in the dash. BRAKES - ABS - TRACTION CONTROL - Also get a message to service Advance Trac. Is there some sort of reset that needs to happen? Or do I need to just go out and drive the car a few miles. Thanks, DBEDGE23
So after replacing the fuse block - everything seems to be working fine. However I have three dash lights that are on - BRAKES - ABS - Traction Control - Is there some sort of reset I need to do?
Thanks!!! I think this is it! DBGOLF23
Had the fuse blow on the positive side of the battery... I did search the forums but when I went out to Fordparts.com I can't find the part. Does anyone know where to get this part without having to buy the whole positive cable kit?? Please, any help would be appreciated!!!! Thanks, DBEDGE23
Do you have a rattle in the doors - Try This
DBEDGE23 replied to DBEDGE23's topic in 2013 Edge & MKX
Been driving the car now for about 2 weeks since I fixed those covers underneath the car. Let me tell you the car was never more quiet!!! It sure did fix a lot of rattles. Just sounds so much more solid, even when I go over bumps. Hope this post helps. Thanks, DBEDGE23 -
I did not. Pretty straight forward. Let me know if you have any questions. -
Just thought I would post my fix to the crowd here. I have a 2013 Edge Sport and have had a rattle that sounded like was in the doors on both sides of the car. Louder on the driver side than the passenger side. And I could only hear it when driving on the highway. Try this fix. Get under the car and see if the two plastic covers are rattling. These covers are right under both seat locations under the car. I took out the tabs and put some dynamat on a couple locations that were hitting the metal of the undercarriage. Rattling problem solved. I think the wind from the highway driving was moving them and causing them to rattle. I hope this helps and again I do have the 2013 Sport so not sure if these covers come on all Edges. Thanks, DBEDGE23
Decided on HIDs, now what?
DBEDGE23 replied to Sparkles's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I have a 2013 Sport - 9006. But it might be the same for 9005. Just try both rings when installing.
