ErikB
About ErikB
397 profile views
ErikB's Achievements
  1. Has anyone towed a boat with their Edge? How big is your boat and what is it weight?
  2. Did you go with the same size rotors or did you go bigger? And I assume you kept your stock calipers too?
  3. Is there a good suspension upgrade for the edge to help with it? What has anyone else done?
  4. Do I even need front and back? I guess the real question is if I just put the steeda one on the back won't the car then oversteer ?
  5. As far as upgrading. Would getting slotted roters(same size) and good pad be enough of an upgrade? Or should I get bigger roters and calipers? And if I enlarge my roters won't I have to get bigger wheels too?
  6. I guess a trailer with brakes would probably be a good idea then. It might be a good investment as well!
  7. I have a 09 3.5L SEL and my wife and I want to get a boat. I see that I can get a class III hitch that installs on the Edge but my concern is the tow capacity. Ford states 3500lbs/600lb TW. Does anyone tow anything heavy with their edge and what is your experience. I am looking to tow between 3000-4000lbs but my biggest concern isn't towing itself but getting this boat up out of the water off a boat ramp. I don't want to get stuck. What are people towing out there with there edges?
  8. Has anyone found a good set of front and rear anti-sway bars for the 09 SEL? I can only find Steeda's and they don't make both. Thanks!
  9. Has anyone been able to find a class III hitch that fits on the 2009 SEL?
  10. Has anyone noticed this smell on the NON-AWD models? I have a 2009 SEL and I am getting a strong odor only outside the vehicle not in the cab. But I am wondering if I should start my fight with ford now since in am well within my CERTIFIED warenty.
  11. I have a 2009 SEL but NOT the AWD. is this problem only in the AWD models? I get a strong smell only on the outside of the car but it is a very strong smell like you are all describing. I am well within my CERTIFIED warranty so I want to start my fight too if I need to.
