NCG8R
Everything posted by NCG8R
  1. This is probably my best option. Looked around today and there are several styles that may work. I just need to make sure my accessories can insert far enough for pin hole alignment. I now got something to do this weekend. Thanks!
  2. The hitches out there (HiddenHitch, Draw-Tite, ...) bolt to the frame (most say no drilling required) so there wouldn't be a new weld to worry about.
  3. If I remember correctly, towing package includes a larger radiator, extra or bigger cooling fan, larger battery, wiring harness, & hitch. I don't remember if anything changes for the transmission cooling.
  4. Just got my '08 Limited with towing package. My intent was to replace the 1 1/4 inch receiver with a 2 inch one. I assumed (don't do thet again) that I could unbolt Ford's and bolt on a new one with some minor trimming. I didn't know Ford would weld it on. I only occassionally tow a 2000 lb trailer so this set-up can do that but my accessories (bike rack, hitch basket, ...) are all 2 inch. Should I have the Ford hitch cut off and install the one I need OR just get a 1 1/4 to 2 adaptor for accessory use? Is cutting off the Ford hitch even an option? Thoughts appreciated!
