thebrave
About thebrave
thebrave's Achievements
Key Fob is on the big side. What I have run into is my three attached keys tend to reach the panic button when it is in my pocket. Have set Panic off 3 times in two weeks. No biggie, but since I usually ignore those sounds, I now have to look to see if it is me!
Large Hand Sanitizer
Now that it's here - Trick or quirks you are finding
thebrave replied to choff1138's topic in 2011 Edge & MKX
Right again, as usual, Waldo. The new Edge is an incredible improvement over the older Edge. The drive and quiet ride is so much better, it is hard to believe. The fact that there have been very few reports of mechanical issues speaks volumes. -
Thanks. Great detailing help for the rest of us.
My SD card was missing on my Edge when delivered from factory. When you start the car, the upper right corner of the touchscreen (the NAV corner) shows " SD card fault" if the SD card is not inserted.
Report your new 2011 Ford Edge or Lincoln MKX delivery here!
thebrave replied to LIVIO's topic in 2011 Edge & MKX
Congrats on the new Edge. Thanks also for the help on lowering the Nav Voice. Needed that a bunch. Hopefully, when we get a few more Edges out there, we can work together with tips like that one to help us jump up the learning curve even quicker. Enjoy! -
I agree that there is so much to learn. Voice recognition system seems MUCH better then old Sync. But still...just getting started. 1. Asked for "nearest pet store" Got a list of paint stores. 2. Asked for J.C. Penney Got a list of chinese restaurants. 3.Lists of restaurants include several that have been closed for over 4 years. But, 4. Change temp requests worked perfectly for us. "Climate...change temp to 72 degrees" 5. Passenger can make vocal requests just as easy as driver. 6. Navigation appears to be much more accurate than upgraded DVD in 2007 Edge. 7. Home is easy to set in Nav. 8. Radio presets and tuning are very easy and intuitive. 9. Sync services work perfectly. More later.... -
UPDATE #2 from Hannibal, MO Navigation SD card showed up as result of special order from Ford this afternoon (missing on my Edge), installed in less than 1 minute and is working perfectly. No other problems that I have discovered. Earlier questioner: After about 320 miles of mixed driving (70% highway, 30% city), looks about 21.4 MPG. I gauge it about 1 MPG better than the old V-6 Edge. Mostly impressed with the quiet interior, nice firm ride, and ease of use on MyTouch. Hope your new Edge gets to you quickly.
UPDATE #2 from Hannibal, MO Navigation SD card showed up as result of special order from Ford this afternoon (missing on my Edge), installed in less than 1 minute and is working perfectly. No other problems that I have discovered. Earlier questioner: After about 320 miles of mixed driving (70% highway, 30% city), looks about 21.4 MPG. I gauge it about 1 MPG better than the old V-6 Edge. Mostly impressed with the quiet interior, nice firm ride, and ease of use on MyTouch. Hope your new Edge gets to you quickly. -
UPDATE #1 and a Problem: OK, the sticker was $41,920 USD minus the $1000 rebate (302A rapid spec with rubber mats as only listed option). I am just a loyal Ford buyer. There are several Customer Loyalty rebates listed also, but they are full of restrictions and I did not qualify even though we own 2 other Ford products. I traded a 2007 Edge, so my out of pocket is probably meaningless. I can tell you that it was about that standard deal that you see on Consumer Reports, etc. with middle to high Blue Book values for the trade-in. I did not price the 2011 Edge as a cash only deal when we ordered. The only problem with the new Edge is that the SD navigation card (replaces the DVD for Nav) was not in the vehicle when it was unloaded at the Dealer. So when your car is started, you get an SD card error in the Navigation window. It is supposed to be in a packet in the glove box. They immediately ordered a replacement ($795 USD cost if you lost one) and it should be here on Tuesday. Disappointing but minor issue in the scope of things. Very enjoyable drive and ride. Hope all of you get yours soon.
Hi All, Took delivery of my 2011 Edge this afternoon from Tom Boland Ford in Hannibal, MO. Originally a customer order dated April 1, this Edge was duplicated with an identical dealer stock order as the factory rep. knew that order would be filled first. It is a Silver Limited AWD and looks exactly like the silver model in the 360 look on the Ford website. Spent about a half hour riding around, and sitting inside. Quieter ride than my 07 Edge. Haven't done any setup yet on the MyTouch. You can feel the extra 20 horses in the 30-40 MPH range during accelleration. Low end seems about like the older Edge, but smoother than the old transmission setup. That's it for now. Hope the nav and sync are easy to set up. More later.
Hi All, Took delivery of my 2011 Edge this afternoon from Tom Boland Ford in Hannibal, MO. Originally a customer order dated April 1, this Edge was replaced with an identical dealer stock order as the factory rep. knew that order would be filled first. It is a Silver Limited AWD and looks exactly like the silver model in the 360 look on the Ford website. Spent about a half hour riding around, and sitting inside. Quieter ride than my 07 Edge. Haven't done any setup yet on the MyTouch. You can feel the extra 20 horses in the 30-40 MPH range during accelleration. Low end seems about like the older Edge, but smoother than the old transmission setup. That's it for now. Hope the nav and sync are easy to set up. More later. -
Hi Again, My new Edge (Silver AWD Ltd.) shows up today on my dealer's online inventory (the dealer stock order that duplicated my April 1 order) along with another white one. The dealer confirmed that it had shipped. Only one other Edge shows up in online inventory at a St. Louis dealer. A couple of Edges on the Quincy IL dealership's listing, and a couple of MKXs at the same Quincy dealership and a few St. Louis dealerships. I do not think any of these vehicles has shown up on the lot yet. Good luck to all of you waiting along with me. OK Waldo, you were right about ship dates.
Received a call from my dealer this afternoon. No news yet on my 2011 Edge (ordered April 1, then duplicated with a dealer stock order at a later date due to those orders being shipped first). They have been told that shipping has been delayed due to "an electrical and/or software problem." Makes sense, as national adverts still are featuring 2010 Edges and MKXs today. Also, dealers in the midwest have not had their traditional show and tell or whatever they call it at one of the area dealers where sales folks can preview the updated Edge. Not always done with an update, but probably would be with the new MyFord Touch. Autoweek reported that the new Edge started shipping to dealers today, will be $200 less than the 2010 model, and "Ford is planning a television and digital ad campaign to launch the model starting in late August and early September." Let's hope so.
Well, we are all getting excited. My order was entered on April 1, but have heard nothing yet. I bet a bunch of Edges will show up just as the commercials start to play on TV. For whatever reason, I still feel like there has been some sort of delay, as Ford's announced late summer rollout is bumping up against their traditional new model introduction times.
