jmbreeze23
Everything posted by jmbreeze23
How often do you put on your emergency/parking brake?
jmbreeze23 replied to flymore's topic in Brakes, Chassis & Suspension
That's great! We had a 1974 Toyota Corona 4 speed. It was poop brown. LOL The dash was cracked from the sun, so my dad put faux fur on it! Great memories! -
I have basically a similar issue. Rear left caliper is leaking (as confirmed by the dealer today). The brake goes basically to the floor, but car will still stop. If it's pumped one or 2 times, the pressure temporarily comes back for about a second, then back to the floor. I'm not driving it and left at the dealership. My question is, what determines when the brake light indicator goes on? I would think with a fluid leak (or even when I needed the brake booster replaced), that a light on the dash would appear alerting there's a brake issue? The only time the brake light is ever on is when I use the emergency brake in the driveway when it's parked. I have a 2012 Edge limited with approx 154k on it. Thx.
Upside Down Backup Camera
jmbreeze23 replied to patchpony's topic in Audio, Backup, Navigation & SYNC
Mine is a 2012 with 150k miles on it. The grid lines have been gone for many years. The dealer flashed the software and they came back for a few weeks only to disappear again. My camera will do one of 5 things: 1. work as designed (minus the grid lines) 2. display the image upside down 3. screen will flash (like it can't catch up to showing the image) 4. Go totally black with a yellow triangle - says "contact dealership" 5. Or not work at all. The screen just shows all the normal options - phone, nav, radio, climate At this point, since it still works "some" of the time, I'm not willing to invest in a new camera, nor do I want to tear into it myself. Good thing I still know how to use my side mirrors. ?- 5 replies
- reverse
- 2013 ford edge
(and 2 more)
Backup Camera Lines Goes Missing
jmbreeze23 replied to Busablaze's topic in Audio, Backup, Navigation & SYNC
My disappeared several years ago on my 2012 Edge. The dealer reset the camera, but the lines didn't last for a week. Now I'm having the issue with the images being upside down or not working at all. Sometimes I get a black screen that says "Contact the dealership".. LOL So, I'm guessing the camera needs replaced? -
Passenger Blend Door Actuator
jmbreeze23 replied to RNmom0226's topic in Interior, A.C., Heat, Interior Trim
Hi there. Here is a thread where this was discussed and I was able to fix it. Now, with that said, a year later to the exact date, it happened again. Hot on the driver's side, cool on the passenger's side. I'm glad I didn't have to search too deep to find what I did before, as I'd forgotten. I hope this trick works again like it did last July.- 1 reply
Dual Climate Control Repair
jmbreeze23 replied to finzup's topic in Interior, A.C., Heat, Interior Trim
I have a 2012 Edge LTD with the dual zone climate with 106k miles. I also had the issue of blowing hotter than hot air on the driver's side, and cold on the passenger's with the AC on Max. Thanks to this thread, I was able to try the recommendations here. I unplugged the green connector with the car off, plugged back in and turned car on. Turned on AC, still the same result. Next, turned car off, then unplugged connector, and started car. Turned AC on, no changes. Turned AC off, car is still running. Plugged the green connector back in, saw the rod move once I plugged it back in. Turned AC back on and it worked! We'll see how long it lasts. Thank you everyone! -
I have a 2012 Edge and had the same issue. The passenger accordion rubber piece would flap and make noise when I had the roof popped open. Also, the rubber piece would actually slide in the rails when the roof was retracting I dealt with it for a while. Next time I had the oil changed, I had the dealer take a look. He did something to adjust it, but it was really the same issue, no change. Several months later, I retracted the roof and the rubber went back with it. Then I closed it, and the rubber was all wadded up in the front part of the rail. Basically, I ended up having the dealer replace the seals. It was pretty expensive, but for as much as I paid for this car (like others), the last thing I want is the roof to start leaking and ruin the headliner.
I have this too on a 2012 Edge Limited. It's on the driver's side and pops out about 1/4" inch. I regularly push it back in, but the service guy at Ford showed how pushing on the lower front bumper - like wind if you were going down the road, makes it pop back out. It's the way the clip was designed. My other option they told me was ford could replace the bumper cover under warranty... but I would be worried the paint won't match. I like the epoxy idea. I'm going to ask about it again when I take it in for the oil change @ 25k miles.
Front, driver's side bumper keeps popping out
jmbreeze23 replied to HoustonEdge's topic in Exterior & Body
I have a 2012 Ford Edge Limited and the exact same thing is happening! I have 24k miles on it and it's been like this since at least 10k ago. I asked the dealer and they said the clip was not manufactured right and wears out? The option I was provided was to have a new bumper cover installed, but then I would be concerned the paint wouldn't match up. I'm going to ask about it again when I take it in for the next oil change. Just curious, do you hear any rattling (plastic sound) or vibration on the driver's side going down the freeway? I don't know if they are correlated, but it's annoying and seems to have gotten worse. I used to hear it only when it was windy on the freeway - getting the cross wind, but now I hear it almost all the time at 50mph+ speeds. I have not brought the rattling up before with the dealer, but will be doing so on next visit. -
Aftermarket Carpet Floor Mat Review
jmbreeze23 replied to shiggins's topic in Interior, A.C., Heat, Interior Trim
I just ordered this set for my 2012 Edge. It has the front, rear mats + cargo area. I can't wait to get them. -
Thank you for explaining. I think I'd also read online that the 2012s had some additional soundproofing done in the A pillars upfront, so maybe that too helped with it being more quiet.
I wondered what the "soundscreen" meant on the windshield. I thought maybe it had to with the little material shield that pops up with the sunroof. Can you elaborate a little more about what your sales guy said? That was the reason I bought the 2012 Edge as it's so quiet on the freeway. I'd rented one (on accident, was supposed to be a Fusion, but they were out) and fell in love with how there was no road noise. I really didn't know cars could be so quiet.
I did too with mine. I originally financed at 5% for 72 months through Ford to get the $1000 cash back savings. Then refinanced for 2.9% for same term at my credit union.
All weather floor mats
jmbreeze23 replied to hammer23's topic in Interior, A.C., Heat, Interior Trim
Yes, that's what my 2012 $75 ones have from the factory. And that's exactly what happened when we had some snow/salt. So, for now, I have towels over them that go clear up under the pedals and all the way back to where the seat bracket is and across the full width of the driver and also another one for the passenger floor. It looks like an old lady's car with the towels, but at least they are dark. :rolleyes: In my opinion, they are too small for the floor area. I'll be looking at maybe something frome Weather tech or other brands. I like the whole area to be covered, salt or dry. It just keeps all the small stones /debris from getting in the carpet. Jessica -
Power Liftgate Issue
jmbreeze23 replied to milktruk's topic in Alarms, Keyless Entry, Locks & Remote Start
Hey... sorry for the late reply. I got it from Beau Townsend Ford in Vandalia. I have a friend who is looking at one at Germain Ford in Dublin. I told her about the lift gate issue. She mentioned it to the Sales guy there and he told her that I should be getting and SD card sent to me in the mail to fix it. I should know more in about a month when I go in for the first oil change. I'll be sure to post what I find out. -
Central OH -
Great news! Thank you. I thought of this thread the other night while trying to shut it in my driveway. 5 times before it finally shut. Now that there is blizzard like winds blowing, I would have really been irritated standing in the cold fooling with the liftgate. -
I have the stock weather floor mats in my 2012. I hate how there is that slit in the top of it sorta under where the brake pedal is. Salt and misc stuff is already now on the carpet. I am thinking about getting a diff mat/mats for up front.
Great! Thank you for the information! I will be sure to advise my tech of this when I go in. Hopefully in a couple months when I need to take it in, the program will be ready for me to get updated. -
I noticed there is another thread on this topic. Seems like several of us are having this issue. My link -
This also is happening to me, tonight actually. I have a 2012 Limited. Tonight, I got out stuff out of the back, hit the button in the back left cargo area, stepped back and over to the left, only to watch it come down, almost latch and lift back up. So, I repeated same process, only this time, stepped straight back from the lift gate, and it went down and back up. Said a few curse words, and then the 3rd time, used the key fob and it went down and stayed latched. It happened over the holiday. I was showing some family members how it worked and that this was a feature I wanted, and it did it then too! How embarassing. It did it right after I first got the car too. I thought it was user error, but now I know it isn't. It also did it to me several other times/places. It's one thing if it happens in my driveway at home, but being out and about at night/public areas, I gotta stand around and make sure it's going to latch before walking away. Not very safe. I have about 1200 miles on it and will be asking the dealer about it when I get an oil change at 5k.
