riggarob
About riggarob
riggarob's Achievements
  1. Good day all! I have a ? About the beginning of a Premium care plan. Does the plan start when you buy it, for example, one month before the end of the three-year warranty, or does it start at the very beginning when you bought the automobile new. I bought my edge two and half years ago and it only has 7200 miles on it. So if I buy the seven-year plan does that mean it's only good for four years after the initial three-year warranty is up, (this seems to be a common issue) or is it a full seven years after the three-year initial warranty ? Thanks for any info that you can give me.
  2. If you are flat towing (which it's seems you are) you probably have at least a 7 into 4 hook up for your toad lights. All I did was run a wire from the hot pin in the 7 pin plug, thru a 20 amp one way circuit breaker to the hot post on the Edge. Took an hour, and cost 5 bucks. This has been for a year now, no problems since. Also, I run a solar/battery powered wireless stop/directional bar that suction cups to the rear window. Another way to stop any draw on the Edge battery. Robbie '11 Edge Limited AWD, pushing a 42' Fleetwood Providence MH
