Everything posted by 4doorharley
chirping sound outside when I take off from a stop
4doorharley replied to timesaver's topic in Brakes, Chassis & Suspension
Any update on this? Our 2011 (124k miles) sport is doing this pass side also. Thought was brakes, replaced, still there. Found bad sway bar bushing due to leaking power steering filter, replaced, still there. End links were good at that time also. Im stumped Lol.- 15 replies
- chirping sound
- brakes
(and 2 more)
Reflash TSB help mine out. But mine was only doing it every now and then. 2nd time it happen to me, I put it in manual and noticed it was stuck in 3rd gear. And every other time it happen, was in 3rd gear again.
Here is a shot of it out...and tucked under fusebox
- 326 replies
- LED light bar
- LED strip
(and 4 more)
From the album: Misc
Mine has aftermarket HID's and no factory drl's. I will slide the relay back out and snap a picture of it and the area I used.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
What do you need a picture of? Because there isnt much to see, as everything but wires going to the battery are the only ones you can see lol. But don't care to snap a picture of what you need.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
I routed my pass side wire with the factory harness that runs engine side of the radiator. Had more than enough wire. I also zip tied the relay to the hood release cable and slide it under the fuse box. Only done this because of the short ground wire. The ground wire was my only problem/concern with my kit.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
I used the 93 spot for the fuse box tap.........I thought this also(about the relay) until I noticed with the keys out and headlights on, the drl 70% was still lit up. So I swapped the white wire from the headlight circuit to the parking light circuit and it worked like I wanted. I used a small spade connector on the white wire and inserted it into the positive side of the factory pipe light plug, for this install. You can use the parking light wire on the plug you tap into for turn signal also.....pass side and drivers side = yellow with blue stripe(center wire in plug).
- 326 replies
- LED light bar
- LED strip
(and 4 more)
Just installed mine and love them. But I ran into a little issue. I was wanting to keep the courtesy light of the factory setup....pipe light comes on when open door or unlock....you lose this with the edge2's drl when wired by instructions. So instead of wiring up the white wire(headlight trigger) to the headlight circuit. I instead tapped into the parking light circuit. The only down fall to this as I see it now is....You will go to 70% brightness when parking lights are on and when doors are open. This is something I can live with to keep the drl's working as courtesy light also.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
Fuse box is the one next to the battery.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
Mirror cap question
4doorharley replied to 4doorharley's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Yes, I did the research on them. And the majority of used ones are left side. Funny thing is the price of the right side is 5$ higher than the right, when buying new. -
Mirror cap question
No, they only come in black plastic or primed to paint. I thought they would come painted also until I started looking for one.
