spacy73
About spacy73
spacy73's Achievements
  1. Hi, you need only the second cable. Go to www.pac-audio.com or www.bestkits.com and choose you car.
  2. Lebt der Kleine noch? Wird Zeit das die Sommerschlappen wieder drauf kommen...
  3. My picture from the rear cam is ok, but after the update fails the "cancel" button when the picture comes. Has anyone noticed?
  4. Hi, here is the next part, the installation of the camera. This was the first place for testing. It's ok, but not very good. Then I considered the Ford logo detail. There are two pieces. The edge of the Ford logo is the same angle for the camera lens. I disassembled the camera body. Then I drilled with a tap drill a hole as big as the camera lens. The remaining space for the camera is carefully removed with a small cutter(Dremel). Then I have fixed the camera with tape and hot glue. Then the rest of the camera is sealed with Sikaflex. The camera from behind and from front.
  5. This is cool, thanks for the info. Than i can install DVB-T television in my car and the frontcamera can work by driving. :hyper:
  6. Hi Guys, sorry for the delay, but the business comes first... :hyper: Here is the next part, the connection on the MFT. I have used a Kenwood CMOS-310, but you can use another aftermarket camera. The videosignal from the OEM camera on the Ford Edge is a simple FBAS Signal(no RGB). So you can use the input from the MFT without a interface. Connect the camera to ground and ignition. I used a relay with 2 changeover contacts. At rest the signal comes from the front camera, in reverse gear the signal comes from the rear camera. Precondition is, you must enable the "delay" in the rear camera menu on the MFT. The picture of the front camera comes as long as you drive less than 5 mph. You can find the connector C213 under the steering wheel. Connect the relay coil to ground and the other side to the cable for the reversing lamps. The cable is blue/white. You can find it in harness for the rear under the cover from the entry. Use a multimeter to find the right cable. If you have any question, there you go.
  7. Hi, I have installed a Kenwood CMOS-310 Multiview camera in front of my Edge. The picture form the camera comes on the display on MFT. Here is a short video. http://www.youtube.com/watch?v=8RVRfTLdUfw The first view is the backupcamera, the second is the frontcamera with Super wide view(190°). I can change the view with a button. http://www.youtube.com/watch?v=dvVVwsXz0Dk In the next week I will make a little instructions for installation.
  8. Hallo, das klingt super. Ich werde mich melden wenn wir den Smart haben. Ich bin unter +1 248 635 4452 erreichbar.
  9. Ok, dann ruf mich einfach an, wenn ihr da seid/fertig seid. Dann könnten wir vielleicht im Flughafen oder so nen Kaffe trinken. Grüße
    Andreas 0361 6449944
  10. Ok, dann ruf mich einfach an, wenn ihr da seid/fertig seid. Dann könnten wir vielleicht im Flughafen oder so nen Kaffe trinken. Grüße
  11. Hallo, meinte ich doch. :-) ich werde am Mo 02.04.2012 gegen Mittag bei Smart (am Flughafen) in Erfurt meinen 2. Wagen abholen.
    Rene
  12. Na du kommst ja mal auch viel rum. Nich schlecht. Wird es dann am 2. oder 3.4. ? Grüße
  13. Na du kommst ja mal auch viel rum. Nich schlecht. Wird es dann am 2. oder 3.4. ? Grüße
