Everything posted by Weezer
What type and where to buy grease for sunroof?
Weezer replied to DunePearlEdge's topic in Exterior & Body
Ford Fluid XG-8 PTFE Lubricant - Can be ordered from Amazon. -
I have the “Intro-Tech® - Ultimate Reflector™ Custom Folding Auto Shade” for my 2011 Edge. Custom fit – No gaps around the perimeter. Fast, easy to install and remove. Well made. Purchased it here: http://www.carid.com/intro-tech-automotive/ultimate-reflector-folding-shade.html
The hyper flashing is there to inform the operator that the BCM has detected an anomaly in the turn signal’s circuit. The BCM is a computer and therefore under firmware control. Presumably the designers decided it was more important that the hazard warning indicators should flash at the normal rate over indicating a circuit anomaly.
- 35 replies
V-Leds sells an assembly for the V3 Tritons called the CLS. It’s supposed to fix the so called “Hyper Flash” problem. My initial order did not include the CLS. However, after calling V-Leds customer support they told me the CLS would fix the problem. I ordered a pair - one for each assembly - it did not help. The CLS is an aluminum box about 1”x1”x4” and has inside the enclosure a couple of sockets and a 20 watt G4 bulb installed in one of the sockets. They also include an extra 35 watt G4 bulb, neither bulb installed helped. I tried inserting a 6 ohm, 50 watt resistor in the socket in place of the 20 watt G4 bulb, again, no joy.
Weezer replied to exodus's topic in Audio, Backup, Navigation & SYNC
You are correct in that you can’t re-install the update. Regarding your phone not re-connecting, try deleting the phone’s pairing information from the MFT system AND within the phone – then perform the pairing operation anew. Check your MFT system’s settings page to see if the temperature display setting is enabled, it is configurable, now. Search this site for info. on the date problem, it has been discussed here and on the syncmyride.com forum. There is a newer MFT update available (V3.5.1) for download, from here: http://www.syncmyride.com/syncmedia/swparts/Gen2v351build12285updatepackageRev3.exe The above link was copied from TSB12-11-01, which explains the MFT update. If your car has navigation, you’ll need a new A4 navigation map card to go along with the update; otherwise your navigation will cease to work without it. Currently the A4 map card is only available from a dealer. Apparently, Ford will make the V3.5.1 update available for download from the normal syncmyride.com site beginning Dec. 10th, for those without navigation, and sometime in January 2013 for those with navigation. -
Home Screen Wallpapers -- What do you use?
Weezer replied to Cellbine's topic in Audio, Backup, Navigation & SYNC
800 x 378 pixels Right-click on the image and select properties. -
You might want to look into CarPro CeriGlass for removing the scratches from your windshield. The link below is a review and tutorial on the product. http://www.autogeekonline.net/forum/product-reviews/43988-review-carpro-ceriglass.html
- 28 replies
- wipers
- windshield
(and 2 more)
LED Lights 2011 Edge
Weezer replied to RobbN's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
“Also, now with my HID's I notice that at night the front turn signals seem to be overpowered by the HIDS and are not as visible as they were, and links on brighter ones for those front lights as well ??” These look interesting. I’m waiting for a 5k version and some feedback from someone who’s tried them. Http://www.v-leds.com/V3-TRITON-6K-WHITE-AMBER-p9815099-1-2.html -
These will also work. I originally intended to use these in the map lights, but they’re too long (interfered with the ON/OFF operation). But they fit fine in the license plate housing. http://www.amazon.com/9-SMD-White-5050-Light-Bulb/dp/B0047RZRFU
This is my second attempt at modifying the Puddle Lamps. I originally used the x4 5050 LED festoon style replacement, but I wasn’t happy with the light output – just slightly better than the OEM. This second attempt provides significantly more light. The lugs fit snugly over the existing festoon contacts. I added a dab of silicone between the lug and puddle lamp housing to ensure the lugs wouldn’t work themselves free. The LED module’s contacts are not polarity sensitive.
From the album: Puddle Lamp modification
Installed the new MFT update Ver. 3.2.2 the 1st time it was posted on the SMR site. No problems encountered after almost a week of use. Did not lose any saved data, nor did I need to re-pair my phone.
Sending a location from Google Maps no longer works??
Weezer replied to mrdave's topic in Audio, Backup, Navigation & SYNC
It’s not a glitch. Head over to Syncmyride.com forum and look for the topic “Google Maps no longer sends to SYNC”. -
You may want to visit the site below, and perform a search regarding waterless car washes. There are many very knowledgeable detailing types at this site. www.live2detail.com
2013 EDGE CENTER CONSOLE TRAY
Weezer replied to Texasopa's topic in Interior, A.C., Heat, Interior Trim
Look at the photos in the Photo Gallery, by Texasopa. -
Finished assembly. -
LED module siliconed to lens. -
Wires & lugs soldered on. -
Bulb & reflector removed. -
Original Festoon bulb & reflector. -
LED Module - Available in warm, white, cool white
