Spaceman Spiff
Everything posted by Spaceman Spiff
View of my office window pre-covid. Have over 21000 hours, the way things are going not sure if I’ll hit 22000.
Sync 3.3 update stuck
Spaceman Spiff replied to fast67cat's topic in Audio, Backup, Navigation & SYNC
Thanks IRWBB -
My Sync 3 is build 17276 and running fine. Is worth upgrading or “ not fix something that isn’t broken?” spiff -
2011 Edge Sync 2 to 3 upgrade. Comments?
Spaceman Spiff replied to Spaceman Spiff's topic in Audio, Backup, Navigation & SYNC
Hi onyxbfly, reached out to txfrdowner. He currently waiting for parts until February. I’ll wait until then. Thanks again! Really happy with the upgrade so far. -
Gday I just upgraded my 2011 Limited to a Sync 3 system. Straight forward install. So far I’m quite happy with it. Apple car play works well.? The Sync 3 came off a 19 F150 supposedly. The APIM had a 2018 manufacturer date. It’s showing version 3.0 Build 17276 and Maps version NA 1 16. From what I can tell certain 2019 vehicles may be eligible for free nav updates. I’ll try the vin and see if I can the maps updated for free. For actual Sync updates should I even bother since it seems ok for now? Thanks Spiff
Mine doesn’t quite look the same as his eBay pics. I’ll send him a message. I’m sure he’ll have one that works. Thanks again -
Awesome. Thanks so much. i just have the standard sync 2 to 3. -
Thanks again. I have the sync 3 installed now. The person I got it from has wire connected to pin spots on both connectors. It works but I’m not fussy on that connection I’d rather have it connected to real connectors but to cheap to spend $50 on the dtech connector. Lol -
Hi onyxbfly, How did you connect the Sync 3 USB hub to the Sync 2 wire connector? Did you use the Dtech adapter or just made up something? -
Thanks where did you get the parts? Any issues with programming? -
Has anyone upgraded to Sync 3 experience any issues or regret doing it? -
Thanks -
Headlight Bulbs
Spaceman Spiff replied to Sammyg's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thanks -
Headlight Bulbs
Does second Gen Edge -2011 require can bus wiring for after market HID? Spiff -
2nd Gen OEM Pirelli Scorpion tire questions
Spaceman Spiff replied to Chipster's topic in Wheels & Tires
Hi I have around 45000 miles on my Scorpions. 5/32 treadware left on them. I will not be replacing them with the same. These tires suck in the winter. I can't believe Ford would put these on an AWD drive vehicle in Canada. In winter, I found the traction control and ABS always kicking in to the point I don't feel safe in the Edge. I ended up getting a winter set of Nokian Hakkas. Night and day difference. I'll be replacing the Scorp's next spring. Not sure which tires yet but leaning toward Michelin LTX. Will be researching this winter. Spiff -
Piddly but annoying... cargo cover
Spaceman Spiff replied to katandcharlie's topic in 2011 Edge & MKX
brro, did you order the cover mentioned? If so how does it secure towards the rear? Are the attachment clips strong enough? Spiff -
2013 Ratcheting Headrest OEM Brand New Never used
Spaceman Spiff replied to Spaceman Spiff's topic in Classifieds
They have been sold . Thanks -
Was cleaning out the storage room and see that I still have these. I'll take $50 off the prices listed above $150 for US shipping and $125 for CAD shipping. Spiff -
2010-2012 Flex Rims on 2011 Edge, will they fit?
Spaceman Spiff replied to Spaceman Spiff's topic in Wheels & Tires
Closing car washes at 32 degrees because of freezing concerns? Ours don't shut down until it hits -40 lol Spiff -
Hi, I ordered new 20's for a Flex from OEM Direct wheels in Florida. Shipping to Canada was reasonable. Took them to my mechanic's shop to test fit them before putting winter rubber on them next fall. I got the TMPS sensors off of EBay for $60. Thanks to everyone who answered my questions. Spiff -
Thanks for the info UserName. I'm getting the Flex rims as a winter set. Had a rude awakening on the price of winter rubber. The 20's will probably cost an $350ish over the 18's. Sighhhhh I wish the Scorpions weren't so lousy in winter. Spiff -
What size of rubber are you using on the flex rims? Spiff
