Cdpratt69
Everything posted by Cdpratt69
From the album: 2011 Edge Sport AWD
three rockford fosgate amps along the back of the box. One is a 500.4 and runs two sets of RF component speakers up front and in the back seat area, the middle one is the mono 700.1 watt RF amp that runs the two 12's and the one on the far right is a 300.1 mono amp that runs the 10" sub in the factory location. The 10" sub is actually set to play bass between 100-250hz so it runs as a mid base speaker. -
I was satisfied with the job they did. I am really impressed with the shop I use. They are very innovative. The 10" sub on the amp really gave a nice kick to the system but I wanted to do competitions so I went a little crazy after that. Pictures to follow.
Nooooo....I meant I saw your text to my phone about an hour after you sent it but didn't want to call at 1:00am in case you had gone to bed. Then later you posted at almost 2 pm I figured out that you had to be awake at 1:00am. Make sense? Sheesh!
It was really really cheap moonshine! Actually I used alcohol. Isn't go gone just naptha by another name? P.s. I noticed your text a little after 1 am and was afraid to call back because of it being so late.
In a bind I found that corn liquor moonshine works well to remove the sticky goo left on after the badge removal. Thankfully, it was cheap moonshine.
I was going to ask you if you are planning on running a microwave in there. I read further on and sure enough you are!! Hehehe...Hey, throw a garbage compactor, a dishwasher, and sink and you will never have to leave your Edge. I'd live in my Edge for certain! Anywho...good luck with your install. I think you will have the best luck trying to go thru the firewall near the steering column. I've run stuff through there and that rubber is very forgiving and there is actually a good bit of room around the cable bundle. peace out.....
POS means piece of shit...I was trying to be politically correct. The shop just tore out one side of the stock box and then opened up the mount opening enough to accommodate the change in size. The stock Sony amp is anemic so I added a 300 watt Rockford Fosgate amp to help out the new 10" sub. It's been a while since I did it but I believe that mod cost a total of about $575 to include the amp, custom work on the box, an Audio Control LC6i for integration and the low profile pioneer sub.
The wiring harness should already be there for the turn signal. My guess is that they do not change the wiring on the models. It would cost more to have multiple wiring layouts across the different models. Anyhow, it won't be cheap but I bet it is an easy mod.
My favorite shop in Augusta Georgia did a small mod on the factory box and put the low profile ibFlat 10" Pioneer sub back there and you would never know by looking at it that anything was changed. Turn something on with a little bass in it and THEN you can tell for sure. The 8" Sony sub that came from the factory is a POS.
What Exhaust Mods Have U Done???
Cdpratt69 replied to Mike Monaghan's topic in Accessories & Modifications
are you writing to me or someone else? -
I would venture to guess that there is actually about 1/2 gallon left when it quits on you. You could probably use some of that if you gt on a severe angle. You never ever want the fuel lines to run totally dry. That's why not all the tank is available to you. I think.....
IIRC?
I've driven around on a bit of ice and a few inches in snow in my AWD Sport with stock tires and wheels and the car handled well. I took it easy and didn't floor it or anything but it drove and handled well. I was happy with it.
Has anyone switched out the non-lighted door sill plates for the lighted ones? I was wondering if there is a plug in tucked away under the plastic piece that can be pulled off. The instructions say dealer installation recommended but I've never heeded that BS caution before. Anyone done this changeover? Chris
interior visor...it slides...
Cdpratt69 replied to carbonedge+'s topic in Interior, A.C., Heat, Interior Trim
lol -
You're welcome to come on down to Georgia if you would like though. There are a few of us Edge Sport owners down this way.
Brooklyn is a long way for me!
Super nice looking Edge.
