Cdpratt69
Everything posted by Cdpratt69
Custom Halo Headlights
Cdpratt69 replied to mikeblake710's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
looks fantastic!- 26 replies
- headlights
- halos
- (and 5 more)
Good review, thanks!
@Clinton, that's not normal. Is it surging when the a/c compressor comes on or just randomly?
Finally completed my Audio upgrade project.
Cdpratt69 replied to Cdpratt69's topic in Audio, Backup, Navigation & SYNC
Here are some pictures that were requested...- 8 replies
- audio
- subwoofers
(and 2 more)
From the album: 2011 Edge Sport AWD
I need to sand around it just a bit. Some adhesive squeezed out during the install. Otherwise it's nice and I can plug right into there from my computer with a male to male USB cord I ordered. It's a much better option than hiding away the end of the USB cord the unit came with then plugging that straight into your computer. -
I only did a very small few parts of the total install. It is not even comparable to the stock setup. You can't even make day and night look that far apart. The 3Sixty.3 is incredible and I am very glad to have gone through with that upgrade. It was a harder decision than some of the other stuff because of the cost but I would say it is worth every penny. @Markf...I had them put the main 2 gauge power line fuse in the space between the battery and the primary fuse box next to the battery. I will be more than happy to try and shoot some photos of the area where the wire runs through the firewall. I'll post here in the same thread so it will be easy to find.- 8 replies
- audio
- subwoofers
(and 2 more)
Bump!!! This controller works great on the Edge after the Sony amp. It can accept a bunch of the channels that come thru your Sony and thus allowing you to hook up aftermarket speakers for the front and rear doors. There is also a channel for two subwoofers. This is exactly what you need if you want to upgrade your sound without breaking the bank on $700 and $800 controllers. This particular model was installed in the rear right fender near the Sony amp in my Edge for about three months. It worked out famously. I had no problem with the unit and rather liked it. However, I have some kind of "itis" that makes me feel as though I should always be upgrading. It's a dangerous and expensive illness. Anyhow, they list for $149 and is on Amazon for around $119. I'll practically give this puppy away for the first $85 that heads my way. It's in prefect condition. PM me if you want it. I'll go with the first message. I added some info on the unit below for your reading pleasure. by Zak Billmeier Build a system around your factory radio AudioControl's LC6i processor allows you to add aftermarket amps, speakers, and subs to your factory radio, so you can enjoy better sound without losing factory features. It accepts speaker-level signals from your factory radio or amplifier, so you can use it with any system. Inputs and outputs The LC6i features six speaker-level inputs that let you connect amplified signals, including multi-wire cables from Bose® and other premium factory systems up to 400 watts. The LC6i sums all the signals you send it, even if they're actively crossed over by your factory system, so you get a strong, full-range signal for your processors and amps. The LC6i features six RCA preamp outputs that'll handle the traditional front/rear/sub setup. Level matching is a breeze AudioControl couldn't make it much easier to set up your system. Just set your factory stereo to about 3/4 of its maximum volume, and turn the output level control of the LC6i until the "Maximized" light begins to flicker. Adjust the gain controls on your amps and you're done. You've just matched your levels, so you can count on getting maximum performance and minimum noise from your amp setup. Convenience The optional dash-mount subwoofer controller allows you to adjust the level of your sub channel on the go. The speaker-level inputs sense incoming signals and turn on the LC6i, while a built-in 12-volt trigger tells your amps or other gear to turn on.
- 3 replies
- OEM
- OEM integration
(and 3 more)
Pioneer Shallow Mount TS-SW301S/2. Retail on this sub is $179. Amazon is about $70 plus shipping. From me it will go for only $50 plus a few greenbacks for shipping!!! It was only mounted and used for less than three months. I added ridiculous amounts of power so I had to go to the speaker that is right above this one in the Pioneer shallow mount line. This is an amazing shallow mount sub that can easily fit in a box in your spare tire area. They are nice and shallow. There are plenty of other mounting options with this little dude. 12"Max. Music Power (Nominal)1,000 W (250 W)Frequency Response20 Hz to 114 HzSensitivity (1 W/1 m)91 dBImpedance4 ΩMounting Depth3-3/8"Cut-Out Dimensions11"Recommended Enclosure0.5 to 1.0 cu. ft.
- speaker connectors.
- OEM integration
Pioneer Shallow Mount TS-SW301S/2. Retail on this sub is $179. Amazon is about $70 plus shipping. From me it will go for only $45 plus a few greenbacks for shipping!!! It was only mounted and used for less than three months. I added ridiculous amounts of power so I had to go to the speaker that is right above this one in the Pioneer shallow mount line. This is an amazing shallow mount sub that can easily fit in a box in your spare tire area. They are nice and shallow. There are plenty of other mounting options with this little dude. 12"Max. Music Power (Nominal)1,000 W (250 W)Frequency Response20 Hz to 114 HzSensitivity (1 W/1 m)91 dBImpedance4 ΩMounting Depth3-3/8"Cut-Out Dimensions11"Recommended Enclosure0.5 to 1.0 cu. ft. -
Backside -
We broke the asphalt....oops. It's interesting to see the stance difference between the Eibach and the H&R springs. The white Edge Sport is equipped with H&R while the silver model is equipped with Eibach. Not quite the same stance. -
