EdgeNut
Everything posted by EdgeNut
  1. If you happen to own a bike with a carbon fiber frame, you may want to avoid this style of carrier. I'f heard of people having issues with the frame clamp rubbing through the gel coat into the layup, basically ruining the frame. For carbon fiber bikes, look for a carrier that grabs the tires only. Yakima High Roller is a great option if you prefer to transport your bike with both wheels on
  2. 3/32" of tread depth is on the significant side of things, but might not be much different than the mismatch between the mini-spare and a brand new tire. For future reference, you probably would have been fine driving around a little while on the new, mismatched tire, but it could cause some stress on the AWD system in the long-term. For what it's worth, there's a local shop here that will grind down a tire to size for $15. All depends on how much usable tread you have left on the remaining tires.
  3. Sharp-lookin' ride! Definitely like the Sport in red. Hope you enjoy it!
  4. Remember that PWM thing you so astutely brought up? That is how brake pressure can be released smoothly. The valves in these systems are opened and closed at high frequency to gently release pressure. Though I would agree that Toyota doesn't do this very well... ... and, a lateral accelerometer and a yaw rate sensor are completely different things - one measures a linear quantity, the other measures a rotational quantity. There's no confusing those two. And yes, wheel speed sensors are effective at measuring motion. However, the other vehicle sensors can identify if a vehicle is on a hill while stopped, because the dominant external force is gravity, which will show up on the longitudinal accelerometer when the vehicle is pointed uphill or downhill. That's how the systems work without needing the vehicle to roll back... Here's some light reading about stability control from our friends at NHTSA - a good read for learning some basics about these systems, and the federal requirements for OEMs to install them: http://www.nhtsa.dot.gov/staticfiles/DOT/N..._FR_03_2007.pdf Although this has been fun, I think we've wandered far enough away from the original 'trans problems' topic. On that note, happy reading, I'm out... :beerchug:
  5. I suggest you keep studying... If you think you can feel something at 100-150Hz as 'abrupt', you're fooling yourself - these systems can easily bleed off brake pressure slowly, whether that pressure was delivered by the driver's foot, or the stability control pump. I for one have felt how Toyota implements their stability control, and think you may have a skewed perception. Toyota is by no means the leader in this department, and you'll be reminded of that by the constant chime you get whenever stability control kicks in and practically shuts the car down. ... and you left out the fact that all stability control systems include a yaw rate sensor and longitudinal accelerometer (us lucky Ford-types get a roll sensor as well). The longitudinal accelerometer is the one that can tell if you're stopped facing up or down a hill. Maybe Toyotas aren't all they're cracked up to be? I've experienced the hill assist function in the Mini Cooper with a manual transmission, and it's brilliant. Go drive one of those before you suggest that automakers can't deliver a smooth system. Maybe the lack of refinement is specific to Toyota...
  6. Yes, Ford and every other manufacturer/supplier that has stability control has found a way to smoothly control that valve between 100 and 150 times per second. That's not news... ... and the Edge doesn't have any electronic brake application, it's only hydraulic. Some other vehicles have an electric park brake, which is another way hill assist can be implemented, and implemented smoothly I might add. ... and hill assist doesn't engage every time you hit the brakes and come to a stop because the sensors used by the stability control system can tell if you're on a hill, whether facing upwards or downwards. Some hill assist systems will even help you if you're pointed down hill, with the transmission in reverse. Have you ever actually driven a vehicle with hill assist? I ask because these systems are nearly transparent, and quite nicely integrated.
  7. Wrong again... Hill assist systems do not require the vehicle to roll back to engage, as they typically hold some level of driver braking to allow a smooth transition to the gas pedal without rolling back. As the gas pedal is depressed, brake pressure is ramped out. And for what it's worth, stability control has always been standard on the Edge...
  8. Alright, definitely need to clear this one up, as you obviously don't understand why hill descent control is so helpful... Yes, the system uses the brakes, but automatically feathers the brakes to maintain a constant, slow speed. Otherwise, speed will often increase quickly due to changes in driving surface, causing the driver to need to press the brakes harder. As speed increases, and brake pressure increases, heat dissipation increases. Particularly on the grades this system is designed for, you are much MORE likely to overheat brakes left to your own devices, compared to when hill descent control is enabled. You should consider learning more about these systems before you comment so vehemently about them...
  9. Well gang, this has been some fun reading, and I wish you all a wonderful Thanksgiving. As for us, we're heading up to the mountains in our awesome 2007 AWD Edge, which has had absolutely zero problems, driveline or otherwise. The forecast looks good this year, but we'll certainly be laughing at the memories from last year, when we drove through the big Summit County blizzard. Pretty funny watching all those 2WD cars and crossovers that couldn't climb a straight grade, and were slipping sideways into the shoulder!! Cheers! :beerchug:
  10. All of the torque distribution is handled as needed by the AWD and stability/traction control systems (much like the Acura or any other system). Installing different diameter tires would only increase the risk of burning up the AWD hardware, as it will be constantly compensating for the difference in rotational speed between the front and rear axle. Also, it's even more important in winter to have the same tires front to rear to help maintain handling performance...
  11. We've been using the Low Riders on factory rails for our ski rack, and they work great. Very easy to take on and off. Might want to mark where you have them on the crossbars with tape or paint pen, though, since there's only one clamp that secures the rail and crossbar (makes it easier to keep things centered). Plenty secure, though!
  12. Anyone want to sell me their 17" wheels? I live near Boulder, CO, and would consider picking them up in a reasonable area, or paying for shipping.
  13. What kind of bumps? Do you hear the noise when you're going over rough roads, or do you hear it over road undulations and/or speed bumps?
  14. How'd the stability control do with all the flogging? Must have been nice to take it out on a closed track!
  15. For your interior, I highly recommend 303 aerospace protectant, which can be found at most auto stores. On top of the protective quality, it adds a richness to the interior panels without much gloss (read: not at all like ArmorAll). I've used it on my Mazda6, Mazda3, and Edge, and have been very happy with it. Cheers! :beerchug:
  16. Nice fabrication work! (and interesting point about the A-pillar and curtain airbag...) Are you still able to lower the rear seats all the way down with your amps installed underneath? I'm considering an upgrade as well, but thought I'd put the amp under the drivers seat to save the fold-down functionality.
  17. Glad to hear that the dealership was able to find out where the fault was coming from. Hope that cures it for you! We've loved our AWD Edge in the snow - it's great how you can stab the throttle a bit and break the back end loose around slow corners. Almost makes it feel like rear wheel drive when you want it to! Feels very planted elsewhere, with the AWD system working seamlessly.
  18. Hey guys - the lights on the dash indicate a system fault, not the system learning... Even if the lights on the dash are no longer lit up, the instrument cluster will store some fault codes for a certain number of key cycles. Probably best to stop by the dealership and have them pull codes from the ABS module and see what's going on. Might just need a new sensor installed. Hope they're able to help you out!
  19. All 4 tires losing pressure at the same rate? That's quite the statistical oddity... When you measure pressure, the tires should be at ambient temperature, after sitting a while. Is it possible you're measuring pressure after driving a while, or even after the tires have been in the sun for a bit? I've found that, on the same vehicle, tires in the sun can be up to 10psi higher than those in the shade. Even driving in a reasonable manner can raise pressure a few psi after sitting a while. Might be worth having your valve cores tightened/replaced. Maybe there's enough crud in there from the tire shop that they can't seal all the way? Another possibility is that the pressure gage at your tire shop is horribly out of calibration, and you check it yourself with one that is in spec, and agrees with the TPMS sensors? Very strange indeed...
  20. I'm considering an HID conversion kit for my Edge, and have just started the research. I'm not particularly concerned with the installation, but I see some kits use a relay to switch power wired directly to the battery, while some are powered by the factory headlight harness. For those of you who have installed these, should I be concerned about the current spike on startup through the factory harness? I see some members have had flickering problems, but might be due to ballast quality. Can anyone recommend a particular kit? Thanks!
  21. EdgeNut
    G'day
    My wife and I bought an AWD Edge when we moved to Boulder a few months ago, and it has been a great vehicle. Great power up the mountains for our ski weekend in Breckenridge. I don't see too many out there yet, so you'll enjoy a few rubbernecks!
  22. Ummm... I could add some insight, but might not be as thorough as some folks. The low rumble might be normal noise associated with the AWD unit engaging, particularly since you only seem to notice it while accelerating. Obviously can't diagnose it without hearing it, but it's not necessarily problematic. If it's troubling you, it's worth a trip to the dealership for a closer look - that's what free service is for! Just be prepared for the possibility that nothing's wrong! Cheers
  23. Is there anyone in the Boulder/Denver area that wants to sell their rear cargo management system? I'm interested, but would prefer not to deal with shipping. I would pay cash for the pieces, and offer the stock foam pieces and spare tire cover in return.
  24. For those that bought the bumper protector from aslauto - any issues with the rear hatch coming in contact with the protector? Body gaps just aren't what they used to be... :shades: For those that bought the protector from Ford - any issues with durability/scuffing?
  25. Um...dont let those 4 degrees go to your head, man - chill out :shades: Seriously, thermometers are going to read differently whether in a car, weather station, shade, sun, engine bay, etc. Can't even get two weathermen to agree on temperature!
