Everything posted by kc300c
Thanks again for the excellent discussion about our EDGE-2 LED DRL kit. We recently made several improvements to the electronic controller, upgraded amber LEDs and DRL housing of our original EDGE-2 DRL kit (EDGE-2v1). The new EDGE-2v2 kit is very similar to the original in function and installation. Here are my responses to some of your questions: If you want the EDGE-2 DRL's to work as the factory DRL's did you'll need to hook it up this way: (this will allow your DRL's to be on ONLY if parking and/or headlights are on) 1) Long yellow wire from control box connects to passenger side YELLOW/PURPLE parking light wire 2) Shorter yellow wire from control box connects to drivers side BLUE/GREEN parking light wire 3) Red wire from control box connects to battery +, Black to battery - 3) White wire from control box can do 1 or 2 things.... a) keep unhooked and DRL white lights will always be 100% brightness.. or what ever you splice it to it'll be 70% brightness when that function is on. ie. hook it to high beam, they'll dim on high beam, hook to low beam like the kit suggests, the lights will dim when low beam is on, hook to parking lights, they'll be 70% when parking lights are on, etc.. 4) Red Wire with FUSE from control box hooks to the middle parking light wire on the drivers side. Hooking the fuse red wire to the middle of the 3 parking light wires will make the DRL's turn on if your parking lights or headlights are on.. Basically this fuse wire is the main power source wire. So whatever function you hook this wire too, the lights will turn on. (This is exactly right. Automatic on/off DRL function will no longer work. DRLs will now have to be manually switched on with the headlight switch and the parking lights will be on when the DRLs are on. The DRL turn signals will not function if the parking lights / DRLs are not on) Hope this makes things a bit clearer. Your comments and suggestions are greatly appreciated. As I mentioned earlier, I don't have a lot of time to check the forum, so if you have any questions you would like to ask me, please shoot me an email at info@daytimebrightlites.com. You are welcome to post the answers I give you here on the thread. Many thanks, Dan Smith www.DAYTIMEBrightLites.com wwwDriveBright.com
Thanks for the PM Wiz. I have not had much time to keep an eye on the forum lately, so your heads up is very helpful. I'm currently traveling and not able to post a detailed reply right now, but I will by tomorrow. Great discussion by the way. Lot's of good information and very helpful feedback on possible improvements to instructions and wiring methods to provide additional function variations. Check back tomorrow for my reply. Edit: May 8, 2014: We now offer a Courtesy Light adapter wire for the EDGE-2 DRLs. This allows our DRL kits to perform the same way as the stock accent lights did. Click on the picture of our webpage below to go right to it. Instructions are just below that. We recommend only using our harness. Damage to the kit due to improper wiring will void the warranty.
Never use a heat gun! Only the oven method. No more than 260 degrees for 8-10. Then slowly work open the lens. When the lamp cools, stick it back into the one for 5 minutes and continue prying. Key is to keep the lamp warm and taking your time. We are actually developing a blacked out reflector version of our EDGE LED taillight. I'm hoping to have a prototype finished in a couple of weeks. I'll post a picture here when it's finished.
Hey Black. Wanted to make sure you got my reply to your email. I've been falling behind on emails lately due to business travel, but i have been steadily catching up on them. Dan.
- 58 replies
- LED taillight
- LED tail
- (and 8 more)
Hi guys, My LED taillights do have reflector strips. See photo below. The lights also have a chrome reflector under the red lens that reflects light well when the taillights are off. Not that it would matter with my LED taillight, but wannabang is right, no officer would pull you over for having an undamaged taillight not having a reflector designed into into it. My LED Taillights also do not look as if they are a non-OEM aftermarket light. Their desgin and quality of the manufacturing is as good as any factory stock light out there. I have never seen or heard of an Edge with a stock third brake light having your pulsing effect. You may want to check into whether or not you are having a problem with the electrical system.
- 58 replies
- LED taillight
- LED tail
- (and 8 more)
Hi guys, the Ford EDGE has a very flaky electrical system, as many of you are well aware of (especially HID kit users). I have found that about 10% of the Edges that have had my LED kits installed into experience a hyperflash issue. The other 90% don't have any problems at all, including me. (I have them installed in my EDGE). Some customers have been able to eliminate the hyperflash by performing these steps: 1) Flip the LEDs 180 degrees, 2) switch the LEDs from one side to the other, and 3) Move the front LEDs to the rear and the rear LEDs to the front. If none of these cure the hyperflash, I am sending customers a set of resistors at no charge to attach to the turn signal wires (very simple to do with no wire cutting or splicing). The resistors will definitely eliminate the hyperflash. Vortechtrol, try these steps and if they still hyperflash, shoot me an email at info@DAYTIMEBrightLites and I will send you a set of resistors.
Been having the door ajar issue for about a week now. Have to keep closing the door a couple of times to get the warning to disappear.
2013 Edge SE Fog lights
kc300c replied to toast1850's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Hi toast1850. Not sure if you have already purchased the OEM lights, but you may be interested in my EDGE-2 LED daytime running light kit. It is a perfect solution for EDGE SE owners who want to upgrade their blank plastic covers to a super bright true DRL. Unlike having to splice into the factory wiring that you have to do to get the OEMs to work, my EDGE-2 DRL kit comes with an included wire harness and controller that connects to the battery terminals. No wire cutting or splicing. Here is a link to another forum thread about my DRLs and the EDGE SE: http://www.fordedgeforum.com/topic/12945-edge-se-owners-you-can-have-led-daytime-running-lights-on-your-se/ Check them out on our website www.DAYTIMEBrightLites.com -
I have several customers in Dubai. We ship worldwide and to date, we have shipped to customers in over 72 countries.
Edge-ethusiast, the plug configuration I show in the video is a bit unclear. let me see if I can clarify it a bit better for you. My LED tail lights are polarity sensitive. Meaning, that if you plug the taillight wire harness into the stock bulb socket in the wrong way the LED tail lights will not work. I'm trying to describe that the black wire from the LED tail lights plug in the black wire from the OEM wire harness Bulb socket needs to be on the same side of the connection.
glad to see you sold all of your blog lights, Is. now I have one less competitor for my EDGE-2 LED daytime running lights. Lol :-)
LED Edge LED Lighting - HOLIDAY SALES EVENT ENDING SOON
kc300c replied to kc300c's topic in Classifieds
Having HID's has no effect on my DRLs -
HOLIDAY SALES EVENT ENDING SOON Last Day To Save - Sunday, January 5th SAVE Up To $110.00 All LED lighting products are on sale. **NEW Products** - Upgraded LED Puddle Light Option using 800 lumen High Power CREE LED chip - Plug & Play Ford Edge LED Taillights (Complete tail light assembly, not just a replacement bulb kit) - Multi product package discounts **NEW Web store up and running** - Our www.DAYTIMEBrightLites.com website will continue promoting & providing details about our LED products, but will now direct you to our new web store www.DriveBright.com for pricing and ordering. Hope you can take advantage of these savings. Happy Holidays, Dan Smith DAYTIME BrightLites
- 58 replies
- LED taillight
- LED tail
- (and 8 more)
Holiday Sales Event, Save Up To $100 On EDGE LED Lighting
HOLIDAY SALES EVENT ENDING SOON Last Day To Save - Sunday, January 5th SAVE Up To $110.00- 11 replies
- LED
- LED puddle
(and 8 more)
I am so glad you like your new LED taillights and thanks for the nice write up. I'm sure you'll agree that photos don't do lights justice. I remember seeing the first preproduction sample on my EDGE for the first time, just blew me away. There is just no way to capture it with a camera. With the 3D floating LED ribbon parking light having a totally uniform amount of light running along its length, it is difficult to see it. It doesn't have the bright "hot spots" that most other LED taillights have. But as you found, when it gets a lite dark outside, the ribbon is incredibly noticeable. Don't you agree? I have actually been shipping 50W reverse lamp LED with my LED packs. My supplier had run out of 25W bulbs, so he sent me this 50s at no extra charge. The 25W LED are still significantly brighter than the stock bulbs. Thanks again for the business. By the way, the Holiday Sale ends January 2nd, so everyone that has been thinking about getting a set, may want to do it son to take advantage of the savings. Dan
I can't thank you enough for helping me work through adapting our LED tail to the 2008-2010 Edge. I knew you would really like the performance of the new LED tail. The look is so different and unique from anything Ford has made and brings the style up to the level of the more upscale car brands. I am really excited about having the adapter kit manufactured to allow an easy plug & play solution for 08-10 Edge. It will open up a large market for us. thanks again Marty.
- 58 replies
- LED taillight
- LED tail
- (and 8 more)
Boy, this is an old thread. But glad to see it's been resurrected so I can update my last reply from 2012. We now have a true aftermarket vertical LED DRL made specifically for the 2011-2014 Ford Edge. Head over to our website to check them out at www.DAYTIMEBrightLites.com or our new Web store www.DriveBright.com. Our EDGE DRL Kit allows true automatic DRL functionality even on Edge SE & SEL models that did not come with the stock vertical LED accent lights.
LED TAILLIGHT - FORD EDGE (2011-2014) Shadow Black LED Taillight Plug & Play Direct replacement of the stock Ford Taillight. Integrated LED Functions: LED Driving / Position Light - Floating perimeter 3D LED Light Ribbon. - Uniform Ribbon of Light NO hot spots. - Creates illusion that the ribbon is floating inside the taillight. - Unique Modern Style. - Same LED & optical technology used on new luxury vehicles (BMW, Mercedes, Jaguar, etc.) LED Brake Light - Nine Individual LED Reflector cells. - Sweeping curve design. - Extremely bright. - Higher light output than the stock Ford brake light. - Instant on / Instant off: No fade in / fade out like standard filament bulbs. - Perfect match with the stock third brake light above rear window. OPTIONAL Front & Back LED BULB PACK Various Lighting sequences using optional turn signal and reverse LED bulb pack.
- 58 replies
- LED taillight
- LED tail
- (and 8 more)
Just finished editing and uploading the installation video for our new Ford Edge LED Tail Lights:
LED Turn/Tail/Reverse Lights
kc300c replied to Subzero's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Hey Subzero, I know this thread is almost a year old, but wanted to post about our new Ford Edge specific LED tail light replacement assembly and optional LED packs. The new LED tail lights are a plug and play direct replacement unit. Simply pull out your stock tail light, unplug stock tail light wire harnes & sockets and plug them into my new LED tails. Takes less than 15 minutes to install both lights. We also offer optional LED packs that include high power 50 watt LED turn signal replacement bulbs for the front turn signals. Here is our new installation video showing how easy it is and the actual LED operation of these very unique LED lights for the 2011-2014 Edge:
