Everything posted by kc300c
Totally PLUG & PLAY Direct Replacement LED Tail lights for 2007-2010 Ford EDGE – All models Easily replaces the stock tail light assembly on the 2007-10 Ford EDGE (All models). No additional wiring or need for resistors. Just unplug your old stock light and plug in ours. Integrated position, brake and turn signal functions Check them out at www.DriveBright.com Check out the photos and videos below:
Our Bright TRAX LED Puddle lights definitely put out a lot of light, but not so much as to make them seem out off place or overwhelming. The pure white LED color helps to produce a more upscale look while adding to a much safer approach to the Edge at night. We also offer a no risk satisfaction guarantee on all of our products. This guarantee allows you to try out our lights and if you are not totally happy with them for any reason, we will pay the shipping to send them back to us. (US residents only) we will then refund the entire order amount, including original shipping charge. So you won't be out a single dime by giving them a try. We have had this no risk guarantee in place from the time I started this business three years ago. Since then we have produced and sold almost 9,000 LED puddle lights. In those three years, we have had a grand total of six customers who were not happy with their purchase and request a full refund under this guarantee. Many thanks, Dan
Welcome to all of the new 2015 Ford EDGE owners. Our new plug and play direct replacement Bright TRAX LED Puddle Light Pack would be an easy and quick way to brighten up your EDGE at night. Come check them out at www.DriveBright.com Here are some photos of the side by side comparison test of our TRAX lights compare to the stock Ford mirror puddle light and some new vehicle photos we have received from some of our recent customers.
Led Puddle Lights
kc300c replied to Muser99's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Great information on how to run power your puddle lights. I do want to encourage you to add an inline fuse to the hot wire just before it connects to the vehicle wire. Can never be too careful when adding an accessory to a factory circuit. Wanted to also share with you some new photos of our new Bright TRAX LED puddle lights. We have designed our own mass produced product. There is no more need to put down a core deposit, they are less expensive and they are brighter than our previous 5W Cree LED puddle lights. Our LED puddle lights are now 10X brighter than stock and 30% brighter than the old 5W Crees. Check out the side by side photo with the light meter readout. -
Glad to see your new LED tails went in well and you are enjoying them. We have made a revised set of installation instructions specific to the new 07-10 Edge LED taillights. It is still totally plug and play, like the 11-14 taillights. No wire cutting, splicing or tapping and no need to wire in resistors. We have two sets of the 07-10 LED taillights (Shadow Black SPORT) left from the first shipment. We will have another 50 sets in stock by late March/early April (mix of both standard and SPORT). The price for the 07-10 taillights will be $329.00 for the standard and $339.00 for the Shadow Black SPORT version. If anyone is interested in buying one of the two sets I still have available, send me an email at info@daytimebrightlites.com and make the subject: "07-10 Edge Taillights - Forum". We will then arrange for you to place your order. Thanks, Dan Smith DAYTIME BrightLites & DriveBright.com
- 58 replies
- LED taillight
- LED tail
- (and 8 more)
Our HID kit uses a ballast we helped design to eliminate the two most common issues found with universal HID kits, bulb flicker and false-start. False-start is what you are referring to when one or both HIDs will not fire up when the headlight switch is set to auto-on and the engine is started. False-start is caused by insufficient vehicle voltage being supplied to the ballast. Most false-starts occur when the headlight switch is set to auto-on, but some of the lower quality kits can have this occur even when the headlights are switched on manually. I did put a voltage tester on the headlight power wire and noticed an average voltage drop of about 5-10% with the auto-on setting. Most HID ballasts have an under voltage protection feature that will either shut the ballast off or not allow it to start if the voltage doesn't reach a certain level. When we developed our HID ballasts, we actually used my 2012 Edge SPORT as the test mule. We had our HID kit manufacturer add components to the ballast that assures the proper voltage level is present on every headlight start no matter if the switch is set to auto-on or manua and then regulates the voltage during sustained service after initial start up. Besides eliminating the false-starts, the voltage regulation helps increase ballast life. You will see that we also include an external power harness with our HID kits. We found early on that even though our ballasts worked perfectly on their own, most customers preferred installing a wire harness to power their ballasts directly from the battery. The wire harness adds little cost to the kit, so we chose to include it instead of offering it as an after purchase accessory. Our HID ballasts also come with a lifetime warranty and like all of our products, we have a 100% no risk satisfaction guarantee. In short, if you aren't happy with our product, we will refund your entire order amount and send you a prepaid shipping label to return the item back. No out of pocket expense to try out our lights. Feel free to shoot me an email if anyone has any specific questions about our quality HID kits. Thanks again, Dan Smith DAYTIME BrightLites and www.DriveBright.com
HID Drive Bright HID kits
kc300c replied to DKS's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thanks for the kind words guys. Glad you are enjoying our lighting products on your EDGEs. I would love to see you guys post some photos of your EDGEs with our lights running. -
New tail lights from Dan
kc300c replied to The Whedge's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Hi all, thanks for the thread on our new Edge LED tail lights. I'm not sure when I will be able to get a video put together of the new Shadow Black tails, but here are some additional photos that may help. We have been getting some great reviews on these new lights from customers. I guarantee you will like them. They add so much to the look of the rear end and the brake light LEDs are much brighter than the stock tail lights. We are just about to begin production of the same taillight that will be compatible with the 2007-2010 Edge. I am hoping to finish them by sometime in January. I will be sure to post to the forum when they are ready. Our Shadow Black LED Tail light compared to the Stock Ford SPORT tail light: With Optional Turn signal / Reverse Lamp Rear LED Bulb Pack: NEW Product Coming soon: EXTREME V4 LED Puddle Light We are just about ready to launch a brand new LED puddle light that is 40% brighter than our already incredibly bright High Output CREE LED puddle lights. Hope to have them up on the site by the end of the weekend. Look for the new thread I will start here on the forum, to introduce them. All Edge Products are also ON SALE right now with the lowest prices we have ever offered. Check them out: DriveBright.com Holiday Sales Event -
Just got my DLR kit installed
kc300c replied to arabski's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I know I'm late to the party on this, but glad to hear you like your DRLs. They look great on your blue SPORT. My tooling company fixed the RH / LH labeling on the housings. I'm just glad that each individual DRL can only fit into its mating opening.- 6 replies
- DRL
- Drivebright
I know, I know. As Scotty on Star Trek says, "I'm given 'er all she's got, Captain!"
- 58 replies
- LED taillight
- LED tail
- (and 8 more)
Sorry for not replying sooner. We are working on a 2007-2010 version of our LED Taillight. I am hoping to have it finished and ready to ship in early January. I will be sure to post a reply when I have a firm date. The new taillight will be completely plug and play, so no wiring in adapters and such will be necessary. It will be available in the new Shadow Black style:
- 58 replies
- 2
- LED taillight
- LED tail
- (and 8 more)
Map light bulbs on 09 Edge/MKX
kc300c replied to enigma-2's topic in Interior, A.C., Heat, Interior Trim
Hi enigma-2, We offer an interior LED package for the Edge, including your 2009. We just began a sales promotion today and our LED Dome Light with interior LED bulb pack is $10.00 off. Here is the link to the product page: DAYTIME BrightLites Edge Interior LED Package -
New Product Announcement Shadow BLACK LED Tail Light ON Sale NOW - SAVE $50.00 only at www.DriveBright.com - PLUG & PLAY Direct Replacement LED Tail lights (2011-2014 Ford EDGE – All models) - Easily replaces the stock tail light assembly - Integrated LED Functions: LED Driving / Position Light. New Shadow Black Interior Reflector - Updated & more modern look - Elegant and Sporty all-in-one look. - Darker appearance maes for a great replacement option for an Edge SPORT look without the need of a smoke tinted lens for even brighter LED light output. - Makes the 3D light ribbon and brake light features really pop out, day or night. Floating 3D LED Ribbon - Totally unique Floating Perimeter 3D LED Light Ribbon. - Uniform Ribbon of Light with NO hot spots. - Creates illusion that the ribbon is floating inside the taillight. - Unique Modern Style. - Same LED & optical technology used on new luxury vehicles (BMW, Mercedes, Jaguar, etc.) LED Brake Light - Nine Individual LED Reflector cells. - Sweeping curve design. - Brighter than the stock Ford brake light. - Instant on & Instant off LED light: No fade in or fade out like standard filament bulbs. - Perfect match with the stock third brake light above rear window. Optional High Output LED Turn Signal and Reverse Lamp Pack 100% NO-RISK Satisfaction Guarantee* If you are not 100% happy with your purchase, simply contact us within 7 days of receiving your order and receive a complete refund of the original order amount including any shipping fee. We will also send you a prepaid shipping label to send the item back to us at no charge. (US customers only) *Returns must be delivered to DAYTIME BrightLites within 14 days after receiving return authorization in writing from DAYTIME BrightLites / DriveBright.com. Product must be returned in original like-new condition, along with original packaging and all hardware and accessories. Refund will be issue after returned goods are received by DAYTIME BrightLites / DriveBright.com).
Glad to here the K&N CAI works without a tune on the Edge. It has been a couple of years since I was looking into CAIs for my Edge SPORT with the 3.7L engine. Back then, there wasn't a true CAI system (not just a free flow filter) on the market that worked on this engine without causing hesitation, idling issues and check engine warning light. A custom tune was the only way to eliminate these problems back then. I'm going to take a serious look at this K&N CAI. Thanks for the great topic.
First, welcome aboard. Love your SPORT. You mentioned that you would rather have a smaller wheel. You may want to consider posting a thread on the forum asking if anyone with a smaller wheel size wants to do a wheel swap with you. Just a thought.
Welcome FDXGUY. I would love to see some photos too!
LED Puddle lights on SE?
kc300c replied to toast1850's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I have only heard of SE mirrors having the removable round cover where the puddle light would be. Can you take a picture of the underside of your mirror and either post it here or email it to me? (info@daytimebrightlites.com). If you have the removeable cover then all you have to do is run two conductor wire (18 gauge or larger) from the inside of the car to the mirror. The negative conductor of the wire you ran would connect to a body ground (there is a bolt under the trim near the driver's side door frame near the foot well. The positive wire would then connect to the dome light power wire. (IMPORTANT: always install an inline fuse on the new puddle light positive power wire just before it connects to the dome light power wire. Use a 3-5 amp fuse.) Several of my LED puddle light customers have done this and were very happy with their upgrade. -
Welcome to the Edge family and to the forum. I love the color on yours!
I wouldn't recommend wrapping tape around a plug connection. Over time, moisture (in liquid form or vapor) will eventually find its way under the tape. And when it does, the tape will actually hold the water in, not allowing the moisture to evaporate causing even more rapid corrosion than if the plug connection was left uncovered. The best option is to squeeze a liberal amount of a good dielectric grease into both connectors, then plug them together. The dielectric grease doesn't hinder the electrical contact, but will seal any liquid or vapor out. I use it on all of my connections both inside and outside the vehicle. You can find it at any auto parts store.
Thanks for the write up on the problem and work around on your HID kit. This should be helpful for those Edge owners who have the TRS kit. For those looking to add an HID kit to their Edge should also take a look at our HID kit. I developed our kit specifically with the Edge in mind. I found a manufacturer who was willing to produce an HID system that eliminates all of the flickering and false starts that so many universal HID kits seem to have. Our fully digital AC canbus HID ballast assemblies have an integrated capacitors to allow the HID bulbs to fire up without issue especially with the "auto-on" headlight switch setting. For some reason, the auto-on setting causes a slight fluctuation in power to the headlights which can cause the HID ballasts to fail to start. Our ballast circuitry and integrated capacitor compensates for this initial power fluctuation and feeds the appropriate inrush current to our ballasts and lamps. Guaranteed starts every time. Check out our HID kit here: http://drivebright.com/home/product-category/hid-headlight-replacement-kit/
Thanks for the link. The Edge will likely need a custom tuning program installed in order for the engine to run correctly with this type of intake.
I had this happen on my daughters car. Turned out to be a loose plug under the seat. (Probably caused by someone kicking all of the junk that my daughter lets pile up on the floor behind her seat. When I went to see if I could find the problem, I felt like I was a magician performing the "pull the endless handkerchief from the sleeve routine". I couldn't believe how much stuff could fit under her seats. I did come out with $1.73 in change though. Not quite hourly shop rate, but better than nothing ;-).
Welcome to the forum and congrats on your new Edge. You will get used to the Edge quickly. I drive an Edge along with another vehicle and I still find myself having to get used to the funky turn signal stalk operation ;-).
Hi Vexer, Welcome to the forum. You'll find a lot of useful information and a lot of helpful folks willing to answer any questions you may have. As for your HID kit inquiry, My company offers an excellent HID kit that was developed to work flawlessly on the Ford Edge. If you have done any HID kit searches here on the forum, you will hear about a lot of problems people have had with many of the HID kits out there. I was one of those people who tried several kits and could not find one that didn't have flickering or false start issues. I found a manufacturer who was willing to help design and produce a kit for me that eliminated all of the problems caused by the Edge's electrical system. Check out the HID kit at our web store www.DriveBright.com. Here is the link to the HID kit page: http://drivebright.com/home/product-category/hid-headlight-replacement-kit/
