jimmkx2k11
Everything posted by jimmkx2k11
Is the 2015 MKX really Generation II? I thought 2016 was the first year for MKX Gen II? Thanks
Hello, I have a 2017 mkx. Behind the passenger side door rear window, the larger black (plastic?) window trim piece seems discolored. Is it easy for service to fix or do they have to take apart half the door trim to replace it? Thanks
1) Hot air rises so this might be normal. Is it possible to 'reboot' just the climate system with a certain fuse pull?
MyFord Touch version 3.6
jimmkx2k11 replied to jeffdelta's topic in Audio, Backup, Navigation & SYNC
Direct download here http://www.fordservicecontent.com/pubs/content/~WT/~MUS~LEN/3580/tsb13-08-02.pdf -
Auto Climate Won't Shut Off After 5.2.1 Update
jimmkx2k11 replied to ls973800's topic in Interior, A.C., Heat, Interior Trim
I don't really use remote start but I set Heater/AC to 'last setting'. This did not help. Thanks -
Hi, Thanks for verifying. Do you by chance remember if your climate unit was on or off when you performed the 3.5.1 update? -
Well, from 'full' auto, I touch floor vent , fan indicator area switches to auto (full auto mode goes off) but the next time I start the vehicle, the floor and auto fan are not engaged. -
Climate auto fan after 3.5.1 update
jimmkx2k11 posted a topic in Interior, A.C., Heat, Interior Trim
Before the 3.5.1 update, I used auto fan (not full auto) with floor vent on. Now, if I set the above and turn the mkx off and back on, auto fan is not selected, floor vent is not selected but 'auto' is on in the touchscreen but not on the center stack. Was fine with 3.2.2. Anyone else experience this? Thanks -
Seems to be fixed now. Thanks
I hope the new update won't take 45-60 minutes just to put back the temp.
Does this test mode work on Edge/MKX? Does it do anything useful?
Were you testing on 2013 model year hardware or 2011 model year hardware. Is there a difference?
Does anyone know if the upcoming update will change anything on the left and right screens? (ie. font size for temperature since it will be missing from the center screen?) Thanks
I received the post card also. no mention of a navigation card eh?
Remote start quiet start
jimmkx2k11 replied to exodus's topic in Alarms, Keyless Entry, Locks & Remote Start
Hi, The 'low rpm' setting you speak of means you have quiet start set to on? Thanks -
If I jump to http://www.fordedgeforum.com/index.php?/forum/34-ford-sync-specific-forum/ text does not seem to centered in IE.
Hello, Is it me or is the text in each column (forum, stats, last post info) and the text in the body of each post centered on this site? The ford sync forum is not centered for me. I have not experienced this in any other forum website. Thanks
Major Upgrade (Rewrite) Details
jimmkx2k11 replied to netizenX's topic in Audio, Backup, Navigation & SYNC
I'm sure 'we' will have to go to our fine stealership to get this update. May be able to download it but probably will not get sent a USB stick send via mail. 'We' don't count...example: less SYNC features than USA -
Hello, I have a 2011 MKX. Is the oil filter visible from the top or bottom of the engine. If so, roughly where is it located? Is it blocked by a panel? Where is the oil drain plug located? Thanks
Hi, I don't think the Edge has any sort of cooled seats. The MKX does.
Just ordered. Thanks
Hi, Thanks for the review. Do you have a part number so I know what to avoid? Thanks again.
Master List of Voice Commands
jimmkx2k11 replied to jimmkx2k11's topic in Audio, Backup, Navigation & SYNC
Hi, Not quite the list I was looking for...
