BadAzzSport
About BadAzzSport
BadAzzSport's Achievements
  1. DO NOT ORDER WHEELS FROM THE DEALER!! $1600 a pop!!! you can grab a awesome set of wheels for less than a 1/4 of the price.. Also 30lbs lighter "per wheel"
  2. Looks good man... Ordering mine now along with ebc slotted/drilled rotors.. also finishing up the ny-trex kit.. i'll let you guys know how that turns out with 150hp jets...
  3. I'm usung the pro-zen air intake with a K&N element. it made a noticable difference up past 5k rpm.. makes some noise though. make that a consideration before installing one.
  4. Supercharger designed for 2011 edge sport?????
  5. Supercharger designed for 2011 edge sport?????
  6. Anyone experience check engine light after air intake install?
  7. BadAzzSport
    3.7 Pro-Zen air intake
    3.7 Engine R&D 2011 edge sport
  8. Get a test light and goto the fuse panel. while turning the key on and off find a fuse terminal that goes on when the key is turned on and tap into that fuse... very little current is drawn for a amp remote turn on so there is nothing to worry about in regards to blowing fuses. just make sure u tap into the side of the fuse that is goin on and off, not the constant side... good luck
