fishx65
    11
Everything posted by fishx65
  1. 2011 just hit 150,000 and it's time for a tie rod job. Moog or Motorcraft? Can get all 4 Moog's for $130.00 on Amazon so that's the way I'm leaning.
  2. I recently had to change out an actuator in a Taurus because I couldn't get the defrost vents to work. Major problem in the winter!!!! I was able to pinpoint which actuator it was by the clicking noise and getting my fingers on it. Unfortunately it was the upper actuator on the drivers side which was a bitch to get to. I made a little bed out of milk crates and a patio cushion so I could lay down and try to get the 3 screws out. Took me about 4 hours and I only got two screws back in. Had to go all MacGyver and make a couple extended 1/4" ratchet handles. My whole body was sore for a few days:)
  3. It would be interesting to compare Edge sales to Fusion sales those same years. Maybe cuz I live in Michigan but I'm amazed how many Fusions of all years I still see on the roads.
  4. In the same boat with around 140K on my 2011. Gonna roll the dice instead of fixing something that might last over 300,000 miles. If Mac can do it so can we:):)
  5. I've got a 2011 SEL with 145,000 and been thinking of doing the water pump as a precautionary measure. This post makes me not want to mess with it.
  6. I currently own a 2011 Edge, 2019 Fusion Hybrid and a 2023 Escape ST. The 2011 Edge is way nicer than the 2023 Escape in almost every single way besides technology and MPG. Out of the three, I still prefer driving the Edge by a good margin. I've been driving Fords my whole life but will finally be looking at other brands when I decide to sell the Edge. Whatever I get will definitely be a hybrid.
  7. Your MIL is a smart lady:) I don't think it's worth trying to repair the body on that Edge cuz it's pretty bad. If ya gotta keep it, maybe just keep covering the rust with a can of black rust-stop Rust-oleum.
  8. Probably a CV axle. Make sure to go OEM if they need to be replaced.
  9. You pretty much replaced everything that it could be. Only thing I can think of is another bad CV axle. I replaced mine with an Autozone axle and within a week it started making noise and was out of balance. Had to return it and grab a Motorcraft axle. Nice thing is that round two only took me a half hour:)
  10. I had a dealership diagnose my front clicking noise as a bad strut mount bearing and is the reason I replaced mine before figuring out it was the CV axle. I guess it really doesn't matter in your case since you have an extended warranty.
  11. I just did this a few weeks ago: https://www.youtube.com/watch?v=n1NvtUwfRJc
  12. Wow, it almost sounds like something is preventing the spring or strut from compressing which would explain how the metal around the upper strut bolt is breaking apart. I would think you'd really feel it if the strut or spring wasn't compressing. It would take a lot of force to tear that upper strut mount plate. Has your Edge ever been in a bad accident? Now that I think about it, I did end up removing the 4 upper bolts to turn the strut assembly after noticing it should be installed a certain way. Maybe that could be the problem.
  13. Definitely a bad CV axle and most likely the passenger side. Fairly easy and inexpensive repair.
  14. Exactly how is your strut mount damaged? Besides worn bearings, I really can't see how an upper strut mount can go bad. Are you sure the 4 upper mounting bolts are torqued properly? I, unnecessarily, replaced an upper strut mount a few months ago thinking it was the cause of a clicking sound I had.
  15. It could definitely be front swaybar end links. I had to replace mine at about 80,000 miles on my 2011. Bad links will make a clunking sound when going over bumps. Just like I did with my CV axle, I used cheap aftermarket links the first time and had to replace them almost immediately. I ended up replacing them with a set of Moogs that have zerk fittings and they've been perfect.
  16. If it's a steady loud clicking noise when turning at low speeds the odds are extremely high that it's a bad CV axle. I drove my Edge for about 30,000 miles before I got around to replacing it a few weeks ago. Good news is, it's a fairly inexpensive repair especially if you have the ability to do it yourself with the help of some great Youtube vids. I had to replace mine twice because I made the big mistake of using an aftermarket CV axle that I purchased at Autozone. Even if you don't do it yourself, make sure that it's replaced with a Motorcraft axle. Mine was the passenger side.
  17. Make sure to check if your Edge's tray has room for a bigger battery. Not sure about the newer Edges but the 11-14 could take the bigger battery even if they weren't originally equipped with it. If I remember correctly, Edges with remote start already had the larger battery.
  18. Not sure if it's common but the CV axle I purchased at Autozone is not balanced or the CV joints are bad. I'm getting a shimmy when accelerating and it seems to be getting worse. I will be replacing it with a genuine Ford part and getting a refund from Autozone. I highly recommend grabbing one from the stealership for $170.00. Just a quick update: The brand new Auto Zone axle had a really bad inner CV joint. Put the Motorcraft CV axle in last night and it's perfect:) Only took a half hour this time!!
  19. It was pretty easy to get the new CV axle in. I crawled under and held it in place while a buddy tapped it in with a rubber mallet. The whole job from start to finish took about an hour and a half and was exactly how it looked in that TRQ Youtube vid. I just used a floor jack and jack stand to lift the passenger side. My torque wrench only goes to 150 ft lbs so I just cranked the axle nut on with a hunk of pipe which was probably pretty close to 268 ft lbs. Paid $130.00 for the new axle and a 36mm socket from Autozone. No more clicking when turning to the right!!!! It was way easier than I thought it would be:) The $575 quote you received for both sides seems extremely reasonable if it includes both CV axles.
  20. There's a pretty good "How-to" Youtube video by TRQ which makes it look super easy. Ran out to Autozone this morning and grabbed the CV Axle and a 36mm socket. Only took me a half hour to get the axle out but will wait for a friend this afternoon to install the new one. Definitely worth doing if you have the time and a little mechanical ability. I'll edit this post later if I run into any snags putting the new one in.
  21. I just replaced the passenger side strut mount hoping it was the clicking problem in my 2011 SEL. It wasn't so I'm gonna replace the CV axle next. Looks like a fairly easy job so I'm thinking of just grabbing one at Autozone for $110.00 and doing it myself. Mine clicks while turning right at slow speed.
  22. fishx65
    Coolant confusion
    After some research I decided to slowly change out the specialty green with the newer yellow coolant by doing about 4 radiator drain and refills. I did find a few gallons of specialty green for sale but might as well get it changed over since Ford stopped making the green.
  23. If they shine about 3 feet the odds are really high that the bulbs are not installed properly. Someone probably missed a tab and they're both at an angle. That said, 11-14 Edge's have very weak headlights if they came with halogen bulbs. I've run Hids in my 2011 for years but I suppose there are some good LED options out there by now.
  24. That HID kit should be fine. They're all pretty much just cheap Chinese kits at that price range. I finally had a bulb go out in my 2011 yesterday which has been sporting a $45.00 35/5000 DDM kit for almost 10 years.
  25. I usually have it set around 70-73 degrees. Outside temps are below 40. I just reset the system with the power/defrost buttons and there was no change. I hear the blower going in auto mode but nothing is coming out the panel vents. If I switch to panel it blows heat just fine.
