Tires and rims look great!! I always wanted to put a set of off-roaders on my 2011 but it was FWD. My 2022 AWD ST-Line will soon be sporting a nice new set of Falken Wildpeaks.
I ordered two different ones and compared them. This one was way brighter than the other one I ordered:
https://www.amazon.com/dp/B0FM3KWLLG?ref=ppx_pop_dt_b_asin_title&th=1
Very easy install and adds a ton of light to the cargo area.
Looks awesome!!! Does the color temp match the OE headlight led light strips pretty good? Can you please post a link to the exact strip you ordered and the length.
Not sure if you'll know the answer to this question but here it is: I've got a 2022 ST-Line and have the two fobs it came with. I also have an extra one that was programmed to a 2023 Escape that I sold. I was thinking of trying to program the Escape fob as a 3rd one for my Edge since I have the two original fobs for the Edge. Do you think this would work if the Escape fob is compatible??
How long have you had it? I definitely struggled with the dial for a while but now it's second nature and I don't even think about it. Hard to adjust after 40+ years of shifting with a lever.
I made the mistake of using an Autozone purge valve and I've had them replace it under the lifetime warranty 4 times. Maybe you installed a defective purge valve.
I've never vacuum filled any of my vehicles when I just do a drain and refill. I just drain the radiator, refill it and then check the level after the first few drives.
I've always just done drain and refills every 30,000 miles on my Edges. My 2011 just hit 200,000 on the original water pump and my 2022 just had its first drain and refill. I also just did drain and refills on the PTU, RDU and trans.
