20Edge11
Everything posted by 20Edge11
DVD system?
Occasional transmission slipping upon starting after stop.
20Edge11 replied to dudley's topic in 2011 Edge & MKX
What if you have this issue after this build date?? -
Interested can you send me another pic of the headrest in more detail?
Will these fit in a 2011??
2011 Edge SEL adding factory back up cam
20Edge11 replied to 20Edge11's topic in Accessories & Modifications
I am in Canada. a 2011 SEL camera was not included nor available as an option -
SO, when you have a car seat on either side, how much space is left in the middle? Is it useable?
Anyone had luck with this?j -
So I've done some lurking and cant find anything so here I am asking. We have a 2011 Ford Edge SEL AWD (in Canada). 2011's only came with the backup camera in a Limited trim. One day while backing out the Sync through up an error message referencing the rear view camera was not working correctly?? Only happened one time. Looking at the 2012 models it looks like the camera comes on SEL now. I dont think I really need it but am curious if its an easy add on?? Do I just buy the camera and plug n play or does this require a dealer flash that they dont/wont do?? I assume the wiring must already be there?? Thanks
I too cant run the staus checked either???
I have the same problem as you. I have tried mu;tiple downloads onto different thumb drives and it wont install.. Called Ford they walked me through it and said take it to the dealer. I wonder if the rewrite will do the same thing?? I
Sorry I meant your new wheels not the factory ones
Bought 08 Edge 9 days ago...dead in my driveway
20Edge11 replied to HeatherB's topic in 2008 Edge & MKX
In that case disconnect your battery and clean the posts and/or terminal clamps......reattach tightly and try that.....seems thats a likley issue. You should also invest in some dithium grease and coat both clamps to prevent further corrosion. Try that first and post back. -
Those look really nice. Whats the size and model?
Roof Rails with Panoramic Roof
20Edge11 replied to Bingo's topic in Cargo, Hauling, Roof Racks & Towing
Aftermarkets only option such as: http://www.fordedgeforum.com/index.php?/topic/1890-yakima-q-towers-and-bamr/ Can not order BAMR and rails upto 2011, Ford wont sell either, -
A quick look in the right section will find you a thread where its all explained. Browse before you askl -
I really wish this was in out SEL, thanks to what I read on here and Ford's crappy web site I thought I had them. Really really miss them from our Jeep GC but life goes on.
Yakima Q Towers and BAMR
20Edge11 replied to bobbyz95's topic in Cargo, Hauling, Roof Racks & Towing
Found this while surfing: The 2010 Edge missed out on a Top Safety Pick last year after receiving an "Acceptable" score in IIHS roof-strength tests. The old design could support 3.5 times its overall vehicle weight, which was shy of the highest possible "good" rating that requires the roof to withstand four times the vehicle's weight. After coming up short in the test, Ford immediately improved the design and created a roof that withstands 4.7 times the vehicle's weight, surpassing IIHS standards. -
Alberta. I got a DORA yesterday??
BTW I'm in Canada, not sure if that makes a difference but if you are right am i going to get a 2012 then? how would that work? Wouldnt the price change?
I just ordered mine on may 4, 2011 so not sure about deadline???
2011 Edge SEL AWD. IMSRP $$43229 XPLAN $40879
Thats interesting. I figure my number is off by some as well. Will have to check when it arrives.
What did you find out? I am in the same boat. Sure the dealer isnt scewing me over but want to make sure too
Thankss....tough to compare limited vs SEL but it is AWD....guess it's not too bad.
