ferneyhough
Everything posted by ferneyhough
Add subwoofer to '19 edge st with BO sound system
ferneyhough replied to IT_Guy71's topic in Audio, Backup, Navigation & SYNC
Maybe try something from Audison. They have all kinds of stuff for oem integration. https://www.audison.eu/product_lines/prima/ -
Just wondering if anybody could tell me the max size sync 3 supports in terms of Hard Drive capacity? I had a 500gb it worked no problem & just recently purchased a portable 5tb seagate but i can't seem to get it to work. I reformatted it to exfat from the factory ntsf. Any help will do & thank you to all in advance.
Sync 3 Installed in a 2012 Limited
ferneyhough replied to zrt8355's topic in Audio, Backup, Navigation & SYNC
Ok thank you for all your info. I will post an update if & when I get one. -
Can I go aftermarket or do I need OEM? If so do I just tap into the proper pin inputs in the harness at the apim? Thank you. -
Just got sync 3 with nav installed in my 2011 edge sel which was factory nav. My question is my sync 3 is programmed for a reverse camera, when I reverse the screen turnes blue, how can I hook up a reverse camera. Thank you to all in advance. -
Does Anybody know if there is a difference between the 2011-2014 edge interior door panels (skin). Looking to paint my door panels with some SEM paint/products. I was looking for a donor panel to try things out.
I have a 2011 edge sel & was wondering if anybody has ever dyed the interior panels i.e. door skins, front dash, A-B pillars. I want to dye the entire interior to match. I've seen some video's & read some reviews on some products from SEM & Dupont. Still up in the air on what to do. Any info on how to & what products were used would help.
Mine is the same Elotrain I have a 2011 sel edge, nice to know you are not alone
Hertz Mille 3 way set up
ferneyhough replied to ferneyhough's topic in Audio, Backup, Navigation & SYNC
Sorry for the late relpy. The cost me $450 & they quoted my about another $100 to match the pillar. I upgraded the stock wireing through my hole truck to 14 gauge & I am going to be installing a Audison AV 5.1k & a Audison Quattro. Im going to go full active. -
Just figure I'd post some pic's of my custom A Pillar's I had done a few days ago. Sounds amazing but waiting to install my new amps to get the real sound out of these babies
Door panel scratches?
ferneyhough replied to blazindave's topic in Interior, A.C., Heat, Interior Trim
It can be replaced, I had my door skins off eariler in the week & poped mine off. -
heated seat panel button on an 2011 sel
ferneyhough replied to ferneyhough's topic in Interior, A.C., Heat, Interior Trim
Ok Thank You TheWizard for your info -
Here is a PDF file for removing the steering wheel switch. Someone posted it a while back so I downloaded it & saved it, I would lke to thank that person but to be honest I could not remember for the life of me who posted it, but thank you. As for the other panels I have some pic's of the dash taken apart so it will give you a general idea on what you will be expecting.Hope this helps. steering wheel switch.pdf
Yes it did come in & I was not impressed, for $65 bucks all I got was the front panel with no button fml , so the dealer tells me that for another $75 bucks he can order me the button, the only down fall is when you order certain parts like me you can not return them, there is no restocking fee, bummer. So looks like Im gonna have to think about it for a bit, but I wil get back to you with some info when I get it -
Mine works no problem.
Just came across this on Ebay tonight, have a look if your looking to upgrade to an oem system. http://www.ebay.com/itm/2011-ford-Edge-screen-with-cd-changer-OEM-/151007424775?pt=Car_Audio_Video&hash=item2328be7107&vxp=mtr . I'm sure you will need more than this ie harnesses etc, but it's a good start.
The only reason I was asking was because it seems my bitone does not like the cold. The unit takes up to 10 mins to turn on in the -7 degree weather, other than that it does the job I need it to do.
These "Bugs" your talking about in reference to the Audison Bit One can you tell me about them?
Ok thank you all for the info, I will keep you updated as soon as my part comes in -
Looks like Im going to the dealer to order this panel with the buttons on them. probably run me around $100 but in the end I should get a liftgate to work or heated seats to work other than the touch screen I will keep you all posted as soon as I get the part in. -
Ok thank you -
Is there anybody that could pop off their panel on there limited or sport model to help me out? -
Anybody have a PDF file for the 2011 sel dashboard removal?
