tpm419419
About tpm419419
5,561 profile views
tpm419419's Achievements
  1. Just seeing this now. The upper piece cannot be removed without removing the lower 2 pieces?. Just trying to run wire at the base of the upper trim piece where it meets the dash. 2019 Edge Thanks
  2. You need To go under the dash. Taking the access panel off is only good if having someone shine a flashlight through. Basically you need to contort yourself and get on your back to look up under the dash. I hooked up a dash cam power wire so it can be done. good luck
  3. What year is it? If 15 or newer it’s to left of steering wheel by knee height. It’s almost useless except for shining a flashlight. You will need to go under the dash as the fuse panel is tucked up way inside i used the top left fuse I think number 23
  4. Guessing it’s a 2011 or newer. The settings screen to left of speedometer will give you the option to adjust the remote start settings
  5. Agree. I myself am going to wait to see if it’s updated via WiFi
  6. On my 16 I'm pretty sure #37 is on the bottom, left side ( pretty hard to see but it appears that way ) 23 is at the top
  7. Very hard to get to on a 16 model. That taken from the cubby drawer removed
  8. That cubby drawer even has an electrical lightning symbol ( at least on my 16 )
  9. Someone on Facebook said they were auto updated via wifi in February to 2.2. Anyone else get the update via wifi?
  10. I have the update, this is what I can't understand with Ford. It works fine so what are they waiting for? We are only maybe 1% of people on this thread and the other 99% are still waiting. I know I was promised by my salesman back in April of 2016 I would get CarPlay by summer ( 2016 ). With no mention of any cost
  11. Amazing that Ford hasn't released Apple CarPlay software update. What are they waiting for?
  12. What is Ford waiting on? Almost mid March and no public release. I haven't heard of a single issue with those that downloaded and installed it. Only thing I would suggest is a button to exit or enter CarPlay. Right now you need to disconnect the lightning cable from phone
