immgar
About immgar
immgar's Achievements
Community Answers
Re: 2011 Edge Limited AWD, Rapid Spec 302A, 92K miles since new. Q: What is a reasonable cost to repair an inoperative panoramic roof? It will not open or retract, apparently the motors(?) need replacement. The dealer where I purchased the automobile, new - special order, quoted me $15,000.00 to repair and was charged $1,500.00 just to manually close the roof and deactivate the switches. No doubt in my mind that I was ripped off but had no other alternative but to pay the $1,500.00. Would appreciate a response as I would like to repair the panoramic roof before giving the automobile to my granddaughter. Thanks in advance, JV Garcia immgar@aol.com
How To Reset Low Tire Pressure Warning?
immgar replied to immgar's topic in Accessories & Modifications
Was getting ready to remove this posting. Followed my own advised and RTFM...there is a whole chapter on the TPMS that tells me all I need to know. Once the tire pressure is brought up to 35 PSI it will take some driving time at 20 MPH for the TPMS to reset unless there are others issues with the sensors. Have an excellent dealer doing the service, will take it up with them again on my next visit if the warning icon does not goes off. -
Warning on, guessing due to winter's low temperatures in Huber Heights, OH. Last year the dealer replaced all the sensors, is there a way to reset them? Tires pumped to 35 PSI as recommended in door sticker but warning still coming on. Hopefully there is a way to reset and not an added yearly expense replacing them.
Shaay: Sync Update issue is corrected, Dealer found an issue with the APIM and the work order shows that they "updated APIM via USB drive - retest OK". Had experienced issues whenever the MFT or Sync was doing "scheduled updates" in that the system will bombed-out and not reload until after the vehicle was turned off for a few hours. Had a bad experience in a trip to the East Coast when I needed the Navigation maps software the most. Morning after arriving at the destination the MFT/Sync was performing as if nothing had ever happened. What I have read indicates this "APIM" module has a history of problems so will take that into consideration the next time an update is available. Thanks for you insterest and hope those reading these postings can benefit from them - have the dealer check the Advance Protocol Interface Module (APIM) if they are having problems performing the flash drive updates or with the automatic "schedule maintance updates". Closing this as Lesson Learned: 0001
Shaay: After sittting all night, the Sync is now working but the update failed. Will have the dealer do the update tomorrow. Thanks for your willingness and offer to help.
Negative...ran over 3 hours and spend another 2 -3 hours trying to complete it. Called 1-800-392-FORD twice and was told there are some issues with this update version. Recommended to take it to the dealer which I am doing tomorrow. One of your Techs told me that it was safe to shut down the engine and remove the flash drive with the update and Sync would revert to the previous version. No need to tell you that it did not and now I have nothing even radio. Is there anything I can do between now and tomorrow appointment?
Trying to do the latest update via USB flash drive, EAST-14D544-AD.Zip file. The process started about 2 hours ago and still not finished. How long does it takes and if I abort the update can it be restarted later on? Nowhere do I find in these Ford links about Sync what to do if the update fails. 2011 Edge Limite AWD, loaded.
Please disregard...found the update info....
2011 Edge Limited with MFT. How can I find what upgrade have been installed? Recall seen a screen that listed all the installations.
Thanks for your input. Have been wrestling with the gaskets trying to snap them back on but they keep coming out. What really pulls my cork is that having a "PremiumCare" warranty that is supposed to cover bumper-to-bumper for 84 months does not cover just about anything the best I can tell. Guess that's what I have to expect when the electronics go out. I am getting them replaced but I am also going to follow through with Ford for 2 reasons: 1. Defective design and 2. False advised on the extended bumper-to-bumper warranty the dealers pushes that I purchased based on the dealer's recommendations because all the computers system in this CUV.
Have a factory ordered 2011 Edge Limited AWD, fully loaded except of the rear seat DVDs and roof rack since it has a sliding sunroof. The sunroof inner gaskets on both side are off-track. Dealer wants to replace them at a cost of $141.00 each plus labor and taxes. Exhorbitant cost for replacing two gaskets that are off-track. Dealer advisor also stated that "these gaskets have been a problem with this model" hence understood as a bad design issue. Have tried to figured how the gaskets are installed but it is an "accordion gasket" and when seated as soon as the sunroof is open the gaskets goes off track. Have the dealers extended service warranty, PremiumCare- 84 months, and was told this is not covered. Appreciate a company Edge moderator comments. Thanks in advance, Jesse
When is the A7 sc card navigation update due for release? Currently a few versions back, A4, and don't want to update to A6 if A7 will soon be released. Also can I purchased the update version at my dealer? Appreciate a prompt response as I have traveling to do soon.
What is the sunroff made of - glass or plastic? Contemplating applying Rain-X to all the exterior glasses but using it on plastic is questionable. Appreciate a response to glass or plastic? Thanks in advance. 2011 Edge Limited AWD Rapid Spec 302A
