Moderator-
In that specific case, yes. It's the downshift. But ETC also has a built in lag off idle for driveability.
They don’t make a 21” All Season tire
The factory motorcraft oil is a synthetic blend which works just fine as long as you stick with the factory intervals and you're not doing any "severe" conditions.
Anyone ever buy their Edge after lease end?
akirby replied to WingNut's topic in Buying, Leasing & Ordering
Me, either. It's always been a mystery. I'm sure the patents have expired by now considering they've been available for over 20 years. I think Nissan used it on a couple of vehicles about 10 years ago. -
It does mean ZERO fuel for short periods. The wheels and transmission keep the engine turning over until fuel is added again. If the engine couldn’t turn over without combustion you wouldn’t be able to push start a manual transmission vehicle.
Sync 3 has been rated higher than Uconnect in the reviews I’ve read. Sync 3 is fast and easier to navigate than MFT. The only issue I’ve had is the nav volume comes on too high even after you turn it down but that might have already been corrected. -
Most Ford engines do cut fuel while coasting - it’s called DFSO - Deceleration Fuel Shut Off. Not sure if it cuts all fuel to all cylinders at the same time but you can see this by watching the instant mpg when you take your foot off the gas completely.
Pretty sure he was talking about adding it to the vehicle he already bought. The order guide spells out exactly what can be added as options on a factory order.
Doubtful, but if you search online you can find the powertrain warranty details and list of covered components.
There are enough people out there that want the goodies even if they don't fully use them and more importantly, they're willing to pay a premium to get them. In the end, it's all about being able to charge more and make more profit.
Doubtful. Almost nothing is plug and play these days.
It wasn’t just your comparison - reviewers and magazines do it all the time and have for years. They would compare a Lincoln MKZ with a BMW 3 series because they’re the same price. Which is silly. Compare the same size and type of vehicles and note the relative price or performance differences.
remote start horn beep
akirby replied to hborsman's topic in Alarms, Keyless Entry, Locks & Remote Start
This. If that actually starts your car then you’re stuck with the honks because that’s Ford’s way of letting you know you’ve locked the vehicle. Clever design by the aftermarket remote start because it uses the OEM remote, but the side effect is the double honk. No way around that unless you change it for the factory remote start. -
Opposite - use S most of the time when towing (in automatic mode). Only use D at speed on a relatively flat road. At least that’s what I do. Granted, I’ve only pulled a small utility trailer.
Wiring diagrams for Gen II
akirby replied to Philpal72's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
What is it you’re trying to do? -
Ended up getting a replacement set of the Pirelli Scorpion Verde All Seasons 265/40/21 for $1K out the door including free replacements no questions asked from Discount Tire. The noise is gone! Not sure if one slipped a belt or if they just get loud after 20K miles. Worst case I’ll just buy a new set every 2 years.
Sony - Surround sound mode-Your settings?
akirby replied to Chipster's topic in Audio, Backup, Navigation & SYNC
Karma is a bitch.... -
I don’t understand why people continue to do that. They always compare smaller competitors whether it’s a price comparison or performance. You really need to compare the same size vehicles.
I never understood turning the radio off completely. I would go nuts. -
Will Sync3 Update Include Updated Maps?
akirby replied to pintokid's topic in Audio, Backup, Navigation & SYNC
No map updates are included - just the software. They haven’t updated sync 3 maps since it launched. Nobody knows why or when they’ll release new maps. -
That's what I assumed - BCM = Body Control Module.
Only the HID lights get separate fuses in the power distribution box under the hood. Halogens are run out of the smart junction box which probably uses one of the generic fuses (BCM, PCM, etc.). No dedicated fuses for the halogens that I could see.
