Moderator-
Auto shutdown after 30 minute idle
akirby replied to Mikula's topic in 2015+ Edge & MKX Generation II
No it’s not because that requires you to be sitting in the vehicle when you get the warning. By turning it off you can leave it running and not worry about it. -
Correct. It’s not permanent but you can use it to keep the engine running while doing a sync update or something else. -
Of course you can. Under Settings->Vehicle Auto Engine Shutoff. Uncheck it. -
There should be a menu setting to turn it off temporarily. -
Several unnecessary posts have been deleted. I ask one last time - please keep it civil. No more warnings.
Let's keep it civil please.
Nav system Sync 3 issues adding unknow address
akirby replied to Magnetic's topic in Audio, Backup, Navigation & SYNC
I don’t recall hearing about that problem. -
Ford accelerates cost-cutting plan, will drop most U.S. sedans
akirby replied to enigma-2's topic in Articles, News & Reviews
Fusion isn’t going away until 2020. They will probably have a “Fusion Active” vehicle similar to Focus Active. Just not a traditional sedan body style. They’re also betting on getting more customers with hybrids and plug in hybrids - every vehicle outside of Super duty and Transit van. It’s a gamble for sure, but they’ll still have Mondeo and Focus in Europe should they need to bring them back. -
akirby replied to ben senise's topic in Accessories & Modifications
And with voice commands it’s completely unnecessary., -
Most officers seem to prefer the added room of the Explorer over any of the sedans. But I’m guessing the sedans are a little cheaper. -
The actual failure rate is pretty low from a percentage standpoint - probably not enough to make a separate maintenance recommendation. I suspect it's a combination of factors that have to line up to cause the premature failure so it's only really necessary to do more frequent changes if you're in that small group. But since we don't know what puts you in that small group it's just better to be safe and change it sooner.
07edge check engine light flashing
akirby replied to Melissa1015*'s topic in Forum Help & Site Suggestions
Also verify that code. Make sure the original mechanic was correct and make sure that it's not a new problem. -
Both should easily last over 150K miles so to me it's a moot issue.
They're already cutting back rentals and rentals are going more to utilities anyway just like the retail market. And Explorer is the future of Police vehicles not sedans. Ford is pretty much the leader in that area now. Focus production is being replaced with Ranger and Bronco - that's why it was being moved to Mexico originally anyway. No net loss there. Flat Rock is being expanded for autonomous vehicle production. It should also get some new models on the CD6 platform for Lincoln. Taurus production is being replaced with the new Aviator in Chicago. If anything there will be a net increase in US factory production, not a decrease. You have to look at the big picture. -
They can't do that and all the other stuff they want to do with electric and hybrid vehicles. -
It works - you just have to turn on notifications in the Bluetooth options on the phone while it’s connected. And you can put in any destination using voice commands. “Destination Street Address” - then say the address. Works great. -
I dont buy the more stress argument on the 2.0LEB because it was designed from day one for turbocharging including the block and all the components. You never hear those comments about turbodiesels which are designed the same way.
I certainly wouldn't continue driving it with the light on without verifying it with an external gauge. If it just flickers every once in a while it's probably ok but don't wait too long.
Probably the sensor, but did you check the oil level just to be safe?
Bad temp sensor?
2017 edge cargo removal
akirby replied to 2017 SLE FORD EDGE's topic in Forum Help & Site Suggestions
We had a 93 and a 97 Explorer. Great vehicles (at the time). -
Waze via AppLink - is it working?
akirby replied to candurin's topic in Audio, Backup, Navigation & SYNC
Carplay takes over sync 3 completely so you can't run both just like you can't run the OEM nav and carplay at the same time. I don't get using carplay other than navigation. What are folks using it for? -
The newer ones are just like the older ones on the Explorer where it's like a roll up shade.
