    342
  1. Very common problem if you read through the forum. You should have no issues with anything else but I would have the transmission fluid changed and if it’s AWD get that fluid changed too.
  2. Well there’s your 1%. Glad you got it fixed.
  3. Voltage means nothing. 99% your battery is toast. That was a classic symptom in 1st Gen fusions. Have the CCAs checked with a digital tester. If it’s not the battery it might be the connections/cables or grounds.
  4. Asking you to dial it back a little is power tripping? It’s called moderating. You keep apologizing for acting like a dick (your words) but you keep doing it over and over. You’re welcome to stay if you’ll just dial back the personal attacks.
  5. I didn’t say you were wrong I said it’s easy to understand why someone was confused. That’s a big difference between being confused about which vehicle (especially when you’re on one forum talking about a different vehicle) and questioning your expertise. So here’s my point - dial it back a little or we’ll see who wins the pissing contest with the moderator and it won’t be you.
  6. To be fair this is the Edge forum and the engine and tranny don’t have to be removed to do the water pump so that’s a pretty easy thing to confuse. How about you back off on the smugness just a tad?
  7. Yeah but has anyone seen both in person at the same time? Hmmmm…….
  8. Just don’t shut the door all the way.
  9. SUMMARY Please be advised that due to supply chain disruptions, we are forced to make an in-cycle film supplier change for 2 parts on the 22MY Ford Edge. The effective date for this in-cycle supplier change is Jan 6, 2022. All units produced prior to this date will feature the current film supplier. All units produced after this date will feature the new film supplier. The impacted parts are R044D84 (IP applique) and R044H83 (console top finish panel, with cupholder built in). No other parts are impacted by this film supplier change. This change may not be noticeable in isolation, however a side-by-side comparison of units produced before and after the effective date will make the change perceptible and obvious to the naked eye. The differences in color, pattern, and tactile sensation are modest. Every effort has been made to minimize the differences as much as possible.  The appearance difference is not a result of off-quality parts or production errors. The new film supplier is subject to all the same quality standards as the current film supplier. The appearance difference is purely theresult of our need to execute an in-cycle film supplier change to sustain production of the 22MY Ford Edge.
  10. Does Fordpass let you do scheduled remote starts? Im sure there are other solutions available.
  11. Lots of things affect towing capacity including tires.
  12. Are you turning off traction control? That’s probably what’s causing issues - it cuts engine power. In snow you need some wheel spin. I can’t imagine fwd being better than AWD when used properly.
  13. What temperature for the auto setting?
  14. It’s easy to remove the battery. Remove the bracket in the bottom front and the battery slides forward to allow access to the terminals. And factory components don’t usually have labels.
  15. Remove that one bracket at the front bottom and the whole battery slides forward. Super easy.
  16. And your battery management system no longer works.
  17. So you forgot to lock in your financing and you’re calling him the “genius”?
  18. Don’t you love people that ask a question then never come back for the answer? Im guessing she finally realized the lights were turned off.
  19. We don’t get Diesel engines in North America so it may be difficult to find help on this one.
  20. Supply chain issues are real and mostly due to port labor and trucking issues. Ports don’t have enough workers to offload the ships and not enough truckers thanks in part to stupid California over regulation. One guy I know had $70k worth of drum kits sitting on a ship in the harbor for over 3 weeks.
  21. They must have started 2022 job 1 early. Good news.
