    343
  1. You probably didn't reset it after you filled up. It just remembers the number of miles driven since the last reset and how much fuel has been used. If you don't reset it then it's giving you the average since you last hit reset, not the average for the last tankfull. The computer is normally within 1 mpg of the actual measurement - it's very accurate.
  2. The MPG readout never starts over unless you hit the Reset button. You should do that often now since the mileage will continue to improve over the first few thousand miles as the engine breaks in. When you say you can't see how much gas is left, I assume you mean how many miles til empty since you already said you have a quarter of a tank so I assume you can see the fuel gauge. You need to change the display from MPG to DTE (distance to empty) - I think by hitting the Info button one or more times - it cycles through the various readouts. The low fuel message should come on with 50 miles to empty and then will come on every 10 minutes. When it displays low fuel all you have to do is hit the RESET button and it will go away for 10 minutes. You really should read the owner's manual - all this is explained in there plus a lot of other answers to unasked questions.
  3. It's one of those things that if you've never had it you don't realize the benefits but once you use it a couple of times in those situations it's hard to do without it. As for OnStar - why would you want that?
  4. Unless you need to find a destination or an alternate route after you're on the road. That's where the Nav has the biggest advantage.
  5. I'm sure a properly installed class III hitch would get you to 3500 lbs but I would add a tranny cooler for sure. The tranny would be the weak link towing something that heavy. You should also make sure there is no difference in the rear axle ratio with and without the towing package. Probably not.
  6. No video for Sync - yet. But the Sync software is easily upgraded via a USB memory stick downloaded on your computer so I think video and a software based Navigation program are probably likely future upgrades. I don't think you'd have any problems with aftermarket amps. Crutchfield would be a good resource to check what's required.
  7. You should go into the setup menu with the vehicle running and in park and change it. Then go back in and check it. If it won't let you turn it off or it comes back on tell the dealer it's not working. Could be a bug.
  8. Ford does that a lot. G2 is Vivid Red on the Lincoln MKX but Redfire on the Ford Edge. If it's the same paint code then it should be exactly the same color.
  9. According to kbb.com the paint code for the Explorer Limited and F150 Lariat White Sand Tri-Coat is PV. Don't know if it will be the same for the Edge.
  10. No, but if he says he's giving you that price then he should show you the invoice and all of the A/Z/X/D plan prices are right there on the invoice.
  11. Don't believe that. Even if you could get them to match the X plan price they'll still charge you doc fees, etc. You're only going to do better than X plan out the door if the dealer wants to get rid of a car really, really badly.
  12. There may have been hidden dealer incentives that you were not aware of. Did they add a "documentation fee" - that's usually another $400 in profit. It is possible to get a deal like that but only if they're trying to get rid of inventory.
  13. That's hard to believe unless the dealer is adding additional fees or keeping rebates. A plan is actually below dealer cost so without the A/Z plan commission check from Ford the dealer is actually losing money.
  14. One thing to keep in mind - if Mama ain't happy - nobody's happy!
  15. That's why you need to be careful. He might just give you the D plan price but then add on doc fees and/or keep rebates. I didn't think dealership employees could give out D plan pins to non family members.
  16. Buy a set of cheap 17" wheels and the same size 17" tires that come standard on the Edge. The outside diameter should be the same and that's what matters. There should be more options in that size. You could probably even drop to a 16" wheel with larger tires as long as the diameter and bolt pattern are the same. 16" Fusion wheels might work. The advantage is you don't have to mount/re-mount them twice a year - just swap them out when you need them and your 18" wheels will be protected longer.
  17. D plan is for dealership employees and I think it's the same as A plan or very close. You won't beat it that's for sure.
  18. You can order without the PIN assuming the dealer agrees to accept it. You only need the PIN at the time of delivery. However, if you wait until delivery you might not be able to get the PIN so you should have a backup price without the PIN. You can get a PIN now and order the vehicle - just be sure to let your PIN provider know that you've ordered and keep in touch weekly so they don't think you've abandoned the PIN and cancel it. There are PINs available - some people get them and don't say anything. There are posts where folks have said they have PINs available - try PMing them first. And be specific about what you want to buy and when.
  19. You guys aren't paying attention. What you are doing is waiting until the reverse sensor activates, then turning it off. This only works while the vehicle is running and resets once you turn it off. You need to go into the SETUP menu and turn it off there, per the owner's manual instructions. This will turn it off permanently. RTFM
  20. RTFM. Page 104 of the owner's manual: Reverse Sensing System (Park assist) (if equipped) This feature sounds a warning tone to warn the driver of obstacles near the rear bumper, and functions only when R (Reverse) gear is selected. 1. Select this function from the SETUP menu to disable the reverse sensing system feature. 2. Press the RESET control to turn the rear park assist OFF. When R (Reverse) gear is selected, PARK ASSIST OFF will be displayed.
  21. Is "break pedal" a freudian slip? Certainly sounds like your brake pedal is broken. The key is to figure out how to reproduce it on demand or wait until it's doing it and go straight to the dealer and have them check it.
  22. No, you can't use your son's X plan PINs. Those are done through the Ford Partner program and only valid for employees of the partner company and their immediate family. You can go to the Blue Oval News forums and request a X plan pin from a Ford employee under their Friends and Family program. They just gave all the employees 4 more pins for the year so you might be able to get one. The PIN is created with your personal information and the dealer just has to check your ID to make sure it matches the one on the PIN in the database. You need to buy a vehicle or order one within 30 days of requesting the PIN, otherwise the PIN could be cancelled and reissued to someone else. This is to prevent people from getting PINs but never using them. http://www.blueovalforums.com/forums/index.php?
  23. 100% false. Read the owner's manual.
