Moderator-
For the second time it is FAR from useless. I use mine all the time. They don't change existing roads and addresses very often. And I do think they'll eventually offer updates they're probably just extending the interval to save money since a lot of owners are probably using AA/Carplay and their cell phone apps now.
Dealer wants me to trade-in my '16 Titanium, but...
akirby replied to 2FAST4U's topic in Buying, Leasing & Ordering
I get the mental bias but have you actually driven a 2.0L Edge? -
You're not going to get any noticable power improvement from exhaust mods - only a different sound.
Steering Wheel Radio Button Replacement
akirby replied to Kitulu's topic in Audio, Backup, Navigation & SYNC
Had the same problem on a 2014 Escape. Replacing the button fixed it after the dealer first used the wrong button then neglected to actually test it before giving it back, prompting a call to the owner who promptly picked it up, dropped off a loaner, fixed it then delivered it back to the house. -
From previous discussions the difference seems to be M12 vs M14 nuts. M14s are 162 lb/ft. You’re an old Ford engineer - would you follow the factory recommendation on engine bolts?
So you think Ford just changed it for fun? I believe the reason is they use larger studs on some wheels with larger nuts and they do need more torque. It's not like there is some benefit to going way below the recommended torque such as ride quality. I'd get as close to the factory spec as possible.
Are you sure that was Ford? Sometimes those things are dealer sponsored and operated.
The difference is either in the actual Octane rating vs advertised and/or amount of ethanol.
No it won't. They'll just adjust production to match the new lower demand (if that were to actually happen). -
Ecoboost engines seem to have a wider range of mpg depending on how you drive it. NA engines seem to have a much narrower range and is less sensitive. What that means is it's easy to achieve close to EPA test mpg in the real world under the right conditions but it's also easier to get worse mpg than a NA engine. There was also an issue with the first gen ecoboosts where the cylinder heads ran hot and that required the engine to run richer than normal and that hurt fuel economy. The 2nd and 3rd gen engines don't have that problem. Our 2016 MKX has the 3.7L. My F150 has the 3.5LEB. I'm averaging 21-22 mpg in mixed driving. Our MKX is also averaging 21-22 in the same situation. But my truck has about 200 more lb/ft of torque in a much heavier and less aerodynamic vehicle. The 2.0LEB delivers better low end torque (had it in an Escape and a Fusion) and I prefer that to the NA 3.7L in normal driving. You get much better performance off the line without having to rev the engine really high. -
I thought so but I wasn't 100% sure.
You’re usually safe with the OEM sizes but the ST brake rotors might require larger wheels. Base ST is 245/50R20 without the brake package so that would be safe and would have a lot more options. You might be able to get away with 245/60R18s like the SE but you’d need to double check brake clearance.
Consider it cleaned.
Ok, so I'm just going to say this one more time and then I'm going to start deleting posts. If YOU think that the safety benefits are worth the cost and you don't mind spending the money, great. That doesn't mean other people feel the same way and their opinions are just as valid as yours because the probability of being in a serious accident is very very low. It just comes down to what is more important to each person. Now please let's leave it at that and move on.
They still work just fine 95%+ of the time. Even higher in areas that aren't growing fast.
The facts are simple. Buying a new vehicle every 3 years (whether you purchase or lease) is THE most expensive option. Always. In return you get the latest gadgets and safety tech and a full warranty. Buying a used vehicle and keeping it as long as possible is always the cheapest. But you have to do more maintenance and more repairs and you miss some newer technology. Which one is best is an individual decision based on what’s important to you. There is no right or wrong here.
Actually Ford has never mentioned the ST and Sport at the same time. Nor should they.
Interesting. A bad batch of solenoids would explain some of the problems at least.
The difference is usually octane - 93 vs. 87. If the transmission was working correctly the ST might have a slight advantage, but currently the ST is probably the same speed if not slower.
Aftermarket parts do not void the warranty. If the part causes a failure they may not cover that particular failure but the warranty itself is still intact.
Using your logic you could have bought a different vehicle that’s even safer with better crash scores and a higher IIHS safety rating if you think it’s really that important.
Whatever makes you feel better.
I think you’re overstating the safety benefit, statistically speaking. You don’t need to justify your decision to buy new unless you’re just trying to justify it to yourself. In the end it comes down to money and how much you’re willing to spend (or not spend). Neither position is wrong. Can we just leave it at that and move on?
