Moderator-
You might be able to pull a fuse and disable the rear wheels - that should rule out the AWD. The difference is probably the Hankooks versus your other tires.
It won't hurt to check with the dealer to see if they'll reimburse it. Did you check the fluid level in the old battery? These are not maintenance free and require adding distilled water periodically which I didn't think to do. The clicking is almost always a sure sign of a weak battery - it's the starter relay clicking on and off trying to engage the starter but failing.
Sounds like the tires. You need winter tires in really cold weather and/or snow.
Does Edge come standard with alarm?
akirby replied to bri23's topic in Alarms, Keyless Entry, Locks & Remote Start
Yes. -
The bulletin states that cycling the ignition fixes the problem. You said that doesn't fix yours. If it's definitely not the APIM or software upgrade and your speedometer never works then I agree you should be given a new vehicle or a loaner vehicle to drive until yours can be fixed. However, to suggest this is worthy of a class action lawsuit is ridiculous at this point. I do hope you get yours fixed.
Exactly. The battery is toast. Did you check the fluid level? My 08 battery died in a similar fashion and I found it was almost a quart low on fluid. Replaced with distilled water and recharged but it didn't hold. Get a new battery or at least get the old one load tested.
2011 HID Vertical Adjuster
akirby replied to revOevoM's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
It's not wrong - inside the hex opening is a phillips head screw. -
Only if you had the unlimited plan at one time in the past. If you've never had the old unlimited plan then you can't get it now.
I never tried so that might be true.
Big brother is watching
akirby replied to Robert Burke's topic in Interior, A.C., Heat, Interior Trim
That's possible. I think it also estimates mileage in between actual reports. -
X plan plus $500? That's not a discount, that's a ripoff. Maybe they don't really like cops...........
Directional blinker/Rain sensitive wipers questions
akirby replied to drevv's topic in Owner Impressions
You missed reading the owner's manual which explains how it works. You move it to the first stop position and release and it blinks a few times and stops. This is for lane changes. Bump and go. If you're actually turning you move it all the way past the first stop and release and it works just like the traditional turn signals. You're just not pushing it far enough. I don't think they'll work the same with snow. It uses a sensor behind the rear view mirror to judge the amount of moisture. Wait for actual rain then see how they perform. -
It appears that if you did not have tethering on your unlimited plan you must switch to a metered 2gb plan to get tethering now. If you had it before you can probably keep it.
Create a playlist with the songs in the order you want, then play that playlist. With a usb drive you need a specific playlist file format - do a google search or check syncmyride.com for details. Although I don't quite understand why it's easier to click through dozens or hundreds of songs rather than click on one artist or just use the voice control and say play artist.
2 possibilities. 1 - they like policemen and give you an even better price than X plan. They still make some money with the holdback. Assuming that the "police" discount is a normal thing that they always do. 2 - they're charging a lower price for the vehicle and they're making up the difference with huge doc fees, add-ons or other upgrades or they're keeping rebates that you'd otherwise be entitled to meaning your out the door price ends up more than X plan. Remember the dealer also gets a spiff check from Ford for X plan sales so instead of $200 over invoice they'd actually be making about $600 or more. If you know the dealer and this police discount is legit then it's probably #1 - just make sure to check the doc fee and make sure you get any available rebates. One way is to get out the door prices both ways just to be safe.
I have the old $30 unlimited data plan and tethering is not included. I think it can be added for an extra fee but I haven't tried.
Remote start option
akirby replied to thinguy's topic in Alarms, Keyless Entry, Locks & Remote Start
Yes. It's a factory option that's installed by the dealer. Or the dealer can add it aftermarket. -
Some steam and dripping is definitely normal especially after it's first started. If it does it constantly and in low humidity then you might need to get it checked out.
How can I disable seatbelt chime?
akirby replied to Edgar Edgeworthy's topic in Interior, A.C., Heat, Interior Trim
Fasten the seatbelt. -
I don't think that's the case. Like curlysir says it's only updated when YOU enter the mileage. -
Unless it happens twice it's an isolated incident. My son's Focus did something similar a few months after we bought it - hasn't had another problem in 5 years.
