Moderator-
2019 AWD Titanium 13mph 'thud'
akirby replied to Magnetic19's topic in 2019-Current Edge & Nautilius
Check around the spare tire and see if something is loose. -
Click on the picture then click on the gear in the upper right corner and you should have a hide option. I don’t see a delete option.
Option 3 - buy new sensors
If something breaks they can usually tell that it wasn’t stock by the way it fails.
It's all conveniently explained in detail in the owner's manual.
I don't think so. But you can raise up the garage door so that it stops higher and set the liftgate so it stops lower.
Or you could just not close the door all the way.
On my F150 there doesn't seem to be a delay unless I move my foot from brake to gas really really quickly. I do release the brake a split second sooner than I normally would and if I need to make a quick immediate turn from a stop I'll turn it off. Otherwise it works fine. I guess my main point is to actually try it and see if you can live with it first (which you seem to have done) and don't just assume you'll hate it without giving it at least a couple of weeks.
Then the camera has no issues.
The 40 minutes is to allow the keep alive stuff to stop, but I agree most things should be off after 10.
Just to be pedantic - I only see $5750 in rebates. Dealer discount is not a rebate.
I would wait about 45 minutes to be safe.
He meant that it was off center not that he had modified it.
The 2.0L is much more complicated - has 4 long tubes and connectors all over the engine bay. Took me about 3 hours on daughter's escape because I had to remove the wipers and cowl to get to the rear one.
- 2 replies
- emissions
- purge valve
(and 2 more)
Nobody that knows is talking but the last two numbers are torque capacity and the xx35 trannies are only good up to about 300 lb/ft while the xx57 is good up to about 400 lb/ft or more. As to why they used the old 6F as the basis for the 8F57 and not the 8F35 (like they did with the 6F35, 55 and 57) is anybody's guess at this point. Either there were technical issues or it was cheaper/faster.
Which was also a joint GM/Ford design.
It can feel and sound different. Whether it's normal or not is hard to say - best to get the dealer to let you test another one and see if it's the same.
When the purge valve fails it can allow fuel into the canister - especially if you overfill the tank. That's another reason not to go beyond the first click.
