    342
  1. It's just the 202A package which includes everything in the 201A package. Nav was optional not standard but if you have the SD card then you should have Navigation. You should have a navigation menu option (map/destination/etc.).
  2. Torque Converter might not be unlocking. I'd have the dealer check it. What year/model?
  3. Rumor is a new stable update due within the next 2 months and the fully rewritten version either at the end of this year or early next year - not clear yet. But if the next release really fixes the major problems then it won't be a big deal. If not then you certainly have a right to keep complaining.
  4. I suspect it's just frozen in place. Might just need a whack from a BFH.
  5. This could be downgrade assist - are you tapping the brakes when this happens?
  6. akirby
    throttle delay
    I'm just on the other side of 400 right now. Alpharetta cops will put you under the jail if you're not careful.
  7. Nobody here has reported success and the Ford employees are still saying it's not available. I suspect all available resources have been put into fixing the bugs and rewriting MFT and they haven't gotten around to making it a stand alone option that the dealer can install.
  8. That's totally wrong. The X plan price is $34,025. $1500 rebate sounds right but it's hard to tell. With X plan you'll get all available incentives so don't worry about that. Just make sure the dealer runs it through VINCENT.
  9. Dealer name, zip code and vehicle color. Last 5 of VIN would be great.
  10. CAR PARTS ONLY PLEASE! sincerely the moderator
  11. Nobody is making excuses. Ford does appear to be "stepping up" - it's just taking them longer to get all the bugs worked out than they thought. It's 100% Ford's fault and they screwed up royally. But they appear to be doing everything possible to get the problems fixed. If you've never done large complicated software projects then you probably don't understand. Ford even admitted they should have waited a year. But that's water under the bridge now.
  12. Thank you for your service and enjoy the new Edge!
  13. The master reset deletes everything in memory. Pulling fuse 29 does not. There is a difference.
  14. It's perfectly normal although some cars are worse than others. Just crack open another window to equalize the pressure.
  15. Hopefully it's just a clogged drain hose.
  16. Of course they won't because if they did then everybody would just wait until they have a problem to buy the warranty. They'd never make any money.
  17. Of course. Should be the same as charging it from your laptop which takes longer than from the wall outlet.
  18. If you have a PIN you can look up X plan prices for in stock vehicles and get x plan pricing from the build your own feature when you access it through the pin website. But the dealer must show you the actual factory invoice with the X plan price clearly marked.
  19. Because they won't cover a part out of warranty? It was your choice when you bought the car to keep the factory warranty or buy an extended warranty. If you chose not to buy the extended warranty then you have nobody to blame but yourself. It's like choosing not to buy a moonroof and then complaining that Ford didn't give you a moonroof.
  20. Do you have the 5/60 powertrain warranty or just 3/36? Are you out of warranty completely or are they saying this isn't part of the transmission?
  21. It might. It certainly won't hurt anything and it's free!
  22. That is against X plan rules. Report the dealer to the Ford A/D/Z/X plan headquarters.
  23. Motorcraft 5w-20 synthetic blend and a motorcraft filter.
  24. They don't have retrofit kits and the parts would be much more expensive than a nice aftermarket unit.
