Moderator-
NO paddle shifters on the 2019 Edge FWD... WHAT??
akirby replied to tk2fast's topic in Transaxle (FWD)
It’s not a defect and not a safety issue. That’s just how the transmission functionality was designed and that’s exactly what Ford will say - because it’s the truth. -
Probably needs an alignment and/or shocks.
What exactly do you mean by shredding?
You’re assuming the original 9 speed design was optimal and Ford engineers (who worked with GM on the design) don’t know what they’re doing. Number of gears has nothing to do with harsh engagements from a stop which is the current complaint on the 2.0L vehicles with the 8f35. No shifting issues.
Why would you say it’s jury rigged? They tested the 9 speed and found issues so they removed a gear. Each company does their own software. GM has also had problems with their 9 speed. Removing a gear wasn’t the problem.
Probably a combination of losing experienced engineers and diverting resources to work on autonomous vehicles and hybrids/BEVs and other new things. Very disappointing.
Even new batteries can fail sometimes with a dead cell. Probably won’t happen again for at least 3 years.
First, a moderator is just a regular poster who kills spam and keeps posters from attacking each other. Nothing more. My answers are facts, Paddles were deleted for cost cutting. They’re not going to put them back on or change the cruise control programming. It’s not a safety issue and trying to claim it is a safety issue is just silly. live with it or trade it are your only realistic choices. -
Well you should obviously get rid of that death trap ASAP. You'd have to ride the brakes for 5-10 minutes solid (at least) before they came close to being dangerous. Live with it or get rid of it. Whining about it won’t help anybody. -
If you're referring to the purge valve it's under the hood on the driver's side of the engine.
Pricey but these should work well as an alternative.
Let me repeat in case you missed it - this is a BEV - electric only vehicle with a range of 300+ miles. And it won’t look like that.
Tail light Condensation
akirby replied to d0minicano's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Car wash? Hose? -
There are a couple of scenarios where it wouldn't hurt to do it even under warranty - if the mfr refuses to consider it a defect and refuses to replace it or the replacement parts have exactly the same issue. In that case I would just do the modification and not worry about it. -
ECU timing product questions.....Livernois vs Race Chip?
akirby replied to Dieselboy's topic in Accessories & Modifications
I think what they're referring to is that Race Chip doesn't change the ECU programming so it's "theoretically" undetectable. But that's not really an issue. Race Chip and any other external device may or may not work because all they can do is modify existing sensor inputs and that limits both what you can do and the effectiveness. Personally I think they're snake oil. A tune will advance the timing and customize the A/F ratio for safe power increases among other things. IMO it's the only way to go and Livernois has a great reputation especially with Ecoboosted Fords. -
Whatever it says on the label in the drivers door jamb.
The problem is the PTU and other systems are not built to send that much torque to the rear wheels for sustained periods. Just won’t work. Go buy an Explorer ST if you want RWD and high performance.
Why is this site servers so unreliable ?
akirby replied to 1004ron's topic in Forum Help & Site Suggestions
Which history - your 3 years or my 13 years? Stuff happens no matter who you use and it’s not easy to move that many websites to another provider. And this affects a lot of web sites not just this one. -
Thanks Captain Obvious. -
It’s the hosting service. -
They would need to respray the door to make it look right. I did a similar repair myself on our White Platinum Edge (2008) and it turned out great. Go to paintscratch.com and get a touch up kit that includes the base coat, mid coat and clear coat (small spray cans) plus rubbing compound, etc. Sand just the area you touched up. Then mask it off and spray the base coat until that area is filled in and level with the rest of the paint. Might take several coats for a deep chip. Sand smooth with 4000 grit wet sandpaper. Then expose a larger area at least 4-6 inches all around and spray another base coat lightly to blend with the good paint. Feather the paint towards the outside and stop before you get to the masking so you don't leave a line. Then do the same with the mid coat and 2-3 coats of clearcoat. Let it dry at least 24 hours and use the rubbing compound to blend it. Worst case if you mess up they'll just respray the door anyway.
- 1 reply
Remote Windows
akirby replied to seanmarshall's topic in Alarms, Keyless Entry, Locks & Remote Start
That's what I suspected. Otherwise it's a huge safety problem. -
Remote Windows
I don't know if Forscan will override the lack of pinch sensors in the rear windows and allow remote operation. If it does be aware that if something (or someONE) gets caught in the rear window while it's rolling up it will not stop or roll back down. Could be very dangerous which is why it's not enabled from the factory. -
Transmission Flush, or simple drain and fill?
akirby replied to slides's topic in All Wheel Drive (AWD)
Any transmission engineer will tell you that if your filter needs to be changed that your tranny is already toast.- 105 replies
- transmission drain and fill
- transmission flush
- (and 2 more)
