    342
  1. Won’t make a noticeable difference. How many miles?
  2. It’s the server. It’s affecting multiple forums. Robert is working on it.
  3. If your aftermarket plug leaks and the engine seizes up there is no way Ford is going to cover that.
  4. I didn't think there would be a big take rate. Not surprising.
  5. Well that’s a good dealer. They really weren’t obligated to do that. Good luck and next time be sure to inspect it!
  6. First - it’s not really a brand new vehicle. It’s been sitting on the lot for almost a year. That’s why it was $3k cheaper. Unless there was some type of flooding at the dealership (which I doubt) that is normal for a 1 year old vehicle sitting outside. Because it’s not being driven there was no engine heat to dry things off so it rusted a little faster but still looks like normal surface rust to me.
  7. I think they did away with the option to set a custom interval many years ago. Had it on my 06 Fusion but not the later vehicles,
  8. Yes rust like that is normal on any vehicle that’s been sitting outside for 11 months straight.
  9. Nothing formal but point out the offenders and I'll take a look.
  10. Well they do need to have symptoms to get Ford to pay for the update.
  11. Depends on how they're taking it out and where they put it back in. If it uses the transmission cooler lines they don't mix.
  12. Mild surface rust is normal and nothing to worry about. I don't think the tires are rotten, but again I'd have a tire shop look at it. They can test the runout on the tires the same way you test brake rotors to see if there is any variation. They can also check the balance.
  13. It's a software update and I would absolutely ask that it be done prior to delivery. They can't do it until the vehicle is sold. Just say that you noticed some poor shifting on the test drive - that should be all they need to do it.
  14. The tires are probably flatspotted. It may go away or get better in time but it's hard to say. You might want to have a tire shop check them.
  15. Do you mean the accelerator and BRAKE pedal? There are plenty of aftermarket solutions for that, just google it. Ford doesn't offer those. Have you tried adjusting the seat and steering wheel as far forward as possible?
  16. akirby
    Mustang SUV
    I know but folks see that video and think that's how the actual car will look. And Ford sure doesn't mention that in the video.
  17. Yes the 2.7 has a plastic pan. So does my 2018 F150 3.5LEB. I think they switched back to metal on the 2019 F150. The issue is variation in the block but as long as they follow the repair procedure properly it's a permanent fix. But apparently not all the dealers are doing it properly. On a side note I love being able to do oil changes with no tools and I can modulate the oil drainage initially by how far I pull out the plastic plug - and it doesn't spill on my hand or the suspension.
  18. akirby
    Mustang SUV
    That’s not the car. It’s a test mule.
  19. LOL people who can’t admit they’re wrong, They only updated the RWD version, not the Transverse version. You can see it in the torque. The 2nd gen has about 25 more hp than the 1st gen. The 2019 Edge ST has the same power as the 2015-18 sport.
  20. Most of the colors can be found on other vehicles like Explorer which should be in stock at dealers now with pics.
  21. You can see them all here. https://www.ford.com/suvs-crossovers/edge/?gnav=header-all-vehicles
  22. akirby
    Mustang SUV
    Pretty sure both are RWD just with different size battery packs. Longest range should be 300. The smaller battery pack is probably 150-200 miles. Also heard rumors of a high performance AWD version with multiple motors.
  23. The factory produces about 250K vehicles per year which includes Edge, Nautilus and the soon to be discontinued MKT and Flex. Edge is around 140K plus Nautilus at 30K (US sales) plus Canadian sales plus European exports so yes, they do make at least 200K vehicles. But that was just an example. Multiply that by all of Ford's vehicles and the savings are staggering.
  24. They didn’t really start calling it sync 2 until sync 3 came out. It was somewhat confusing.
