Moderator-
Is it really worth the investment? Wouldn’t you get a lot more with a tuner?
Some dealers aren’t following the repair procedure. Try a different dealer.
Which brake fluid should I be using out of these 4?
akirby replied to ThugFordEdge3.5's topic in Brakes, Chassis & Suspension
Never heard of brake fluid viscosity being an issue even in cold climates. Brake fluid is super thin to begin with but I guess low viscosity wouldn’t hurt. -
I don’t see how any of them would perform any differently. -
Go register at blueovalforums.com - all the order guides are posted there.
Ford has had ST-Line models in Europe for many years - alongside ST models. This is not new.
Wouldn't it be cheaper/easier to just buy one of these and wire it into the connector? https://www.amazon.com/BESTEK-300W-Power-Inverter-Adapter/dp/B07Y9M1H88?ref_=s9_apbd_omg_hd_bw_b2RkW&pf_rd_r=92K5TKT119G0JCSES4CF&pf_rd_p=ef88a328-5802-52f1-a22b-1f46a5201df0&pf_rd_s=merchandised-search-10&pf_rd_t=BROWSE&pf_rd_i=583328
Ive said this many times. I would have preferred the 2.0Leb over the 3.7L in our MKX. I just miss that almost instant torque off the line.
I just bought a Rennstand safe jack - should work great on the MKX or any unibody vehicle. A little pricey though. https://www.4wheelparts.com/p/safe-jack-rennstand-by-safe-jack-18m-rs3/_/R-SAJK-18M-RS3?gclid=EAIaIQobChMIrbfKg_LC6QIVF6SzCh2vqgbNEAQYASABEgK8mvD_BwE&ecmp=s:google_9816045574_100845004460__pla-670529025983_Safe Jack_S/J18M-RS3_base_US&utm_source=google&utm_medium=cpc&utm_campaign=shopping&emlprox=out&ppcfon=1&gp=1&ef_id=EAIaIQobChMIrbfKg_LC6QIVF6SzCh2vqgbNEAQYASABEgK8mvD_BwE:G:s&s_kwcid=AL!7836!3!430284196293!!!g!670529025983!&utm_source=google&utm_medium=cpc&utm_campaign=SC Shopping - NTM Desktop&ecmp=s:google_9816045574_100845004460__pla-670529025983
Can I disable artificial engine sound in cabin?
akirby replied to Jombi's topic in Interior, A.C., Heat, Interior Trim
Reports were it was completely disabled but I don't think we ever got an official answer. -
Also true but that's what the software update disabled midway through the 2019 model year. -
It was disabled sometime during the 2019 model year. Software updates will disable it on early build 2019s. -
Accessory power stays active after pressing off button
akirby replied to drm1harley's topic in 2015 Edge & MKX
You probably just need a new battery. They rarely last more than 3-4 years on modern vehicles. A weak battery can cause all sorts of strange issues. I’d replace it then see if you continue to have problems. -
Auto Stop Eliminator For The Nautilus
akirby replied to handfiler's topic in 2019-2020 Edge & Nautilius
Use less brake pressure. -
Not destructive at all. I have pool noodles to cushion it. I’ve used tennis balls and a laser pointer but this works well. No damage. -
Fusion and MKZ, 2007-2009 most likely. Can't remember if the 2010 models changed the wheel specs. If not then 2010-2012 also.
Mine doesn't do this. I park my F150 in the garage and I have to ease into the last foot and actually bump into the wall and it never shuts off until I put it in park and turn it off with the key. Or are you saying that once you stop with your foot on the brake it shuts off but restarts when you put it into park? That's normal. There is no reason to have auto-stop-start in Park. Once you're in Park you can turn the engine on or off yourself. -
No real issues other than some people just don’t like it. Some decide they don’t like it before they even drive it. Others just don’t give it a chance. And it defaults to on at startup ever time. I never had an issue with it aft the first couple of days, -
They are chrome clad wheels (which may have been what adworden meant by "wheel skins"). They are chrome plated plastic epoxied to an aluminum wheel. Not that it matters - it's all one piece. I don't see any other vehicles using that same wheel. Fusion would have been the most obvious but no matches. It may have been Edge only.
Claude - we gotta work on your google skills. https://www.androidauthority.com/backup-android-phone-708622/
