Moderator-
anyone have real world experience with Pre-Collision Assist?
akirby replied to ben senise's topic in Lounge
Had it on my 2013 Fusion. It saved me one day in unexpected extended stop and go traffic. I zoned out while moving slowly forward and had it not alerted me I would have bumped the car in front. It used to activate on my drive into work on a divided 4 lane road. I was in the left lane preparing to turn left at the 2nd traffic light. The road went downhill and then back uphill to the right. If traffic was backed up waiting to turn left at the first light it would activate since it didn't realize the road turned back to the right. At least I knew it was working. -
Door cards.......... Toyota Suh-leek-a (Celica) - we call is Sell-ick-uh BMW Zed4
I’d say the fob is flaky. Try it with one fob at a time.
Never available in NA.
can't program 2013 keyless entry
akirby replied to artaura's topic in Alarms, Keyless Entry, Locks & Remote Start
Does the factory code actually work? Sometimes the digits are backwards. Did you try your new personal code after programming? -
thinking of trading my '16 Ti for a '20 ST and I have a few questions
akirby replied to ben senise's topic in Edge ST
Yes on Titanium and ST models (not ST-Line) but only the front row. -
Windshields have laminated glass. The other windows are normally tempered glass so they shatter into tiny pieces but some vehicles use laminated glass for the doors too to reduce noise. Both can be called safety glass. -
Some useful info here. https://www.f150forum.com/f2/lug-nut-torque-aftermarket-wheels-484176/index5/
Check with the wheel mfr.
You can also either copy and paste the image from your browser or copy and paste the URL to the image. Or save the image to your device and use "choose files" at the bottom left.
Help finding side window deflectors
akirby replied to Gregertech's topic in Accessories & Modifications
You can’t always believe quotes you read on the internet. —. Abraham Lincoln -
There have been many reports of replacement alternators being bad right out of the box, so that's a good possibility. The question is when it drops to 8V at the battery is it still 14.4V at the alternator or does it also drop to 8V? If it's 14.4V at the alternator but 8V at the battery then it's a wiring/connection issue. Also don't rule out a bad replacement battery - make sure they test the CCAs on it not just voltage. Also be aware the alternator may be variable output so it may not always put out 14.4V - could be less (controlled by the PCM). But I don't know if it goes as low as 8V and under normal operation it certainly wouldn't cause the check light.
What does it say in the upper right? If it says information you don’t have nav.
2020 Edge Android Auto Wireless?
akirby replied to smjayman's topic in Audio, Backup, Navigation & SYNC
Pretty sure that requires sync 4 which is coming for 2021 but 2020 has sync 3. -
Check engine with P1450 code on ford edge 2.0L eco boost 2018 model
akirby replied to Sameer's topic in 2.0L EcoBoost
Replaced the purge valve. -
Doesn’t always cause issues. Mine was just the code. -
2016 Ford Edge Intelligent Access
akirby replied to Teresa30's topic in Alarms, Keyless Entry, Locks & Remote Start
. Turn off what? It tells you when you read lamps are on. No need to turn it off. -
Every auto parts store has coolant testers. $3 and up. https://www.autozone.com/heating-and-cooling/antifreeze-coolant-tester?filterByKeyWord=antifreeze&fromString=search&isIgnoreVehicle=false
I wouldn’t recommend it. Most ports do power off at some point. Should be just as easy to connect directly to the battery
Test it. If it’s diluted too much it will show up.
