Moderator-
Keys won't program
akirby replied to Matthew Trepczyk's topic in Alarms, Keyless Entry, Locks & Remote Start
Did you verify that both keys still work? -
Recomendation on a Trailer Wiring Harness?
akirby replied to Sarnano's topic in Accessories & Modifications
The curt wiring harness I used stayed within the bumper on the outside. Only the power wire had to go inside the vehicle behind the taillight. -
So why not find a different dealer? That cost is entirely up to them - Ford isn't involved. I know you're saying Ford should extend the warranty and I agree but since they didn't it's up to you to shop around or DIY.
Come On Ford, Give Me A Break!!!!
akirby replied to All Hat No Cattle's topic in Buying, Leasing & Ordering
ETIS frequently misidentifies the make and model. Everything used to show up as a Transit Connect. If the VIN is correct and the options and equipment is correct then you're good to go. -
No. Mine works on either side of the hitch with no problems. -
Horn sound/warning
akirby replied to Kleber Gomes's topic in Alarms, Keyless Entry, Locks & Remote Start
It was supposed to become a federal mandate but I don't know if that ever happened. It's still a good idea, mandate or not. There are 3 very easy workarounds to avoid it. -
No personal attacks. Post deleted.
akirby replied to jmr061's topic in Audio, Backup, Navigation & SYNC
Sorry I thought I had read that somewhere. You do need to have Siri turned on. -
Horn sound/warning
Two honks in that situation would indicate the car is trying to be locked but a door is open. Perhaps the fob is sending a lock signal inadvertently or the person getting out is accidentally pressing the lock button on a fob at the same time. -
My point was if a bluetooth profile is supported it's the same interface whether it's an Android or Apple device. But I do understand that not all profiles are supported by all devices. And you're correct that every version and vendor you add to the list makes it exponentially more prone to problems and more difficult to test. Apple is easier in that regard.
Did you have carplay running on the phone? -
Horn sound/warning
That is accurate, however it doesn't match the symptoms described which is that the horn sounds when the passenger door is opened not when the driver's door is closed. -
Horn sound/warning
It usually means the engine is running and the door was shut and no key was detected inside the vehicle. Does it happen when the passenger door is opened or closed? -
I used the hidden hitch from etrailer on our MKX - it looks better to me than the other two, same price basically. I think I used the Curt harness plus a cheap metal bracket to hold the connector - no issues, easy install. Just make sure you create a solid ground connection. I tried to use an existing screw without scraping paint and I had to redo it. I tapped into the rear accessory port wiring behind the cargo panel on the driver's side (if you have that on the edge). Works fine. -
Driver floor is SOAKING WET
akirby replied to Blue_Edge15's topic in Interior, A.C., Heat, Interior Trim
He spent 6 hours on it looking for a leak but he never ran any water on it? Seriously???- 478 replies
- missing floor grommet
- new Ford owner
- (and 3 more)
If you can reproduce it with car wash spray it should be easy for the dealer to find it - relatively speaking. I assume you checked the weather stripping around the door?- 478 replies
- new Ford owner
- (and 3 more)
The only thing guaranteed to be consistent is that there is no consistency..... -
They probably changed out the hubs before the 2017 models at some plants. -
Another example of this is the way Internet Explorer used to cover up programmer errors like forgetting to close a tag. Firefox was more strict so you'd have something that worked on IE but not Firefox but the problem was actually a bug in the html strictly speaking. You'd really have to do some deep troubleshooting on the bluetooth interface to figure out where the problem lies.
Any how to's for the VTA mod floating around specific to the Edge?
akirby replied to LNCHBOX's topic in 2.7L EcoBoost
That explains why I don't know what it is. I can't imagine wanting to hear that all the time in an Edge. But to each his own. -
What is a VTA mod? -
That's a good deal. One off the dealer lot just like that is right around $40K with current incentives, maybe a bit less with good negotiating. But add in the no sales tax and that was a steal.
What warranty do I have on Motorcraft/Ford batteries?
akirby replied to trockli's topic in Recalls, TSBs & Warranty
Drive to Advance Auto. Pay $125 for a new battery. Wait 15 minutes while they install it. Drive away.
