    342
  1. That's 2G connectivity rather than LTE and it requires a 2 year commitment. Apples and Oranges. Hopefully it's cheaper than I first thought.
  2. Does that apply to the 2016 MKX as well since it came out after the 2015 Edge?
  3. Not a cash grab. It was mandated by the govt for the scenario Burrcold described. This just worked for my daughter when she had a slow leak. Without it she would have kept driving until the rim and tire was ruined and she may have had an accident. My only issue is it doesn't trigger until it's 25% low. I think it should trigger at 10% - 15%.
  4. No, it doesn't evaporate. The transmission is sealed. It isn't common but does happen. It's usually due to a technical/space issue not cost cutting.
  5. The ecoboost engines have way more torque at lower rpm than larger v6 NA engines. I really miss that torque on our 3.7L MKX.
  6. I disagree. We almost bought a TGTBB Edge. It is definitely blue with hints of green.
  7. That doesn't make any sense. Something is amiss. Is this the factory remote start or dealer installed or aftermarket?
  8. Be sure to check the breaks while you're there.
  9. The topic is titled "does Ford limit speed on the Edge". So excuse me for trying to answer within that context.
  10. I would expect it to be in the $600 range. About the same as a smartphone. I also don't understand the rhyme or reason around the sync connect availability. If it works in the MKX and Fusion it should work in the Edge.
  11. The 2016-17 MKX has it. It was standard on the 2016 MKX reserve.
  12. Well that's what I get for moderating multiple forums. Doh!
  13. When did they change to the dial shifter - 2016 or 2017?
  14. If your verifications are on public roads then that is very much MY business since you're putting me and my family and countless other innocent strangers at risk. Obviously you can do what you want but don't say it's none of our business on public roads. Example?
  15. If you see icons at the top of the reply box you can click on the green square and post a URL to the image or you can choose More Reply Options in the lower right and attach a local picture to the post there.
  16. I hope that was verified on the track and not the street...... It's going to be based on the tires or other vehicle components not local laws or speed limits.
  17. http://lincolnmkxforum.com/uploads/gallery/album_10/med_gallery_932_10_466253.jpeg http://lincolnmkxforum.com/uploads/gallery/album_10/med_gallery_932_10_199356.jpeg http://lincolnmkxforum.com/uploads/gallery/album_10/med_gallery_932_10_117255.jpeg
  18. You have to wonder if Ford is squeezing the suppliers too much. Throttle bodies, brake boosters...
  19. The book labor on the fuel pump is 2.4 hours so at $125/hr that's pretty close.
