Moderator-
LED Light Bar Installation
akirby replied to Mister-Edge's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
That area is open for a reason - you shouldn't block it off with a light bar.- 24 replies
Did you replace the tires with the same brand/model or different ones and if so which ones?
Why do I need to watch the tach in the first place? Ok, we're not going to agree on this one so to each his own. Back on topic since I can't split this out to its own topic.
I know all of that. Waldo's point was you can't just add sync connect to a 2015 Edge because they didn't put in the wiring for the modem. The add-on device for older vehicles which includes the modem and plugs into the OBD-II port doesn't change that fact because it comes with the modem and uses the OBD-II port wiring to connect it to the vehicle.
You need wiring to connect the modem regardless. When you plug into the OBD-II port you're using the OBD-II port wiring which is already present in every vehicle. But the factory sync connect solution doesn't plug into the OBD-II port - it requires dedicated wiring which isn't present in all vehicles.
Give me one example of something that is "unusable".
Well I do have 30 years experience in IT development and architecture, but I will confess I usually prefer command lines to GUIs. I don't have an issue with the colors - I like them. I keep the right hand menu on climate - temperature and the left hand display is on the vertical Tach and fuel economy and that's the way I leave it. The left hand menu system is a little clunky but I rarely use it. The layout could be improved but again it gives me all the info I want the way it is. To me it's more function over form and for me it's perfectly functional the way it is. YMMV.
No video? You're slipping.........
I was going to move these cluster posts to another topic but the moderator permissions are messed up and it won't let me. Sorry.
Just for the record, none of the moderators on any of the blueovalforums related websites (fordedgeforum, fordfusionforum, etc. etc.) are affiliated with Ford in any way. We're just volunteers who love cars and spend a good bit of time on the website anyway so we help out Robert the site owner. I'm not disputing whether you like the cluster or not or whether it's a problem for you personally, but it's still just personal preference. These clusters have been out since late 2012 and I can count on one hand the number of complaints from the Fusion and Edge forums. I for one have no problem finding the info I need at a quick glance nor do the colors strain my eyes. And I know that some people probably bought a Fusion or Edge because of the cluster and the fact that it looks more modern to them (think diehard smartphone lovers). Our MKX is a bit more subdued but I don't have any problem switching back and forth from the Fusion to the MKX.
I have a 2013 Fusion titanium - maybe that's why I like it.
I don't sell cars. I'll say it again - this is just personal preference. I bet a lot more owners like it than hate it.
I think it's personal preference.
You must have loved these....
I don't quite understand - what's the issue with the new Edge gauge cluster?
True but so many people go overboard and you can't see the damn brake lights in the daytime. Also - when the factory does it they must pass DOT tests for visibility so they know for sure they're ok. When you DIY you don't typically have those measurements.
It almost sounds as if the lock button was stuck on the remote or in the vehicle. If it happens again take the battery out of the fob or take it out of range then try the keypad.
- 2 replies
- electrical
- locks
- (and 5 more)
Just so you know both heated and cooled seat settings use the fan - it blows over a peltier device to create the heat and cooling.
Ford Edge 2012 SEL - Radio frequencies
akirby replied to malammouri2015's topic in Audio, Backup, Navigation & SYNC
The dealer may be able to reprogram it. If not you'll have to get a european spec radio. -
That would be my guess.
You're reading it wrong. That's an add-on that plugs into the obd-II port. The factory installed version is completely different.
If you're giving the seller money and you're getting something that cost them money to produce then you are most definitely paying for it.
