Moderator-
Yes - no issues with the hidden hitch. You can kick anywhere between the hitch and the exhaust. Other brands may not work as well.
Sync "Indexing" each time new music added? What?
akirby replied to Denicio's topic in Audio, Backup, Navigation & SYNC
You can use the same itunes playlists on a usb stick. I use a free program called itunes export and it works perfectly as long as all your music files are accessible. If some were moved, deleted or only available via cloud it gets stuck. You can also create playlists manually with the right format. -
Recalls are ONLY for safety issues and no matter how hard you try you are never going to justify this as a safety issue. There is no "Public Need" here. Just a part that sometimes fails. Considering how many Edges and MKXes have been built (well over a million) and considering at least half probably have a Vista roof, the failure rate is relatively low. Things break. Some dealers gouge you but that's not Ford's fault. Sometimes you just have to suck it up.
How the Lease Commissions are Split?
akirby replied to oskar27's topic in Buying, Leasing & Ordering
It's not a law, it's Ford policy. I believe the idea is they do not want a dealer fudging the lease end paperwork for a vehicle they intended to buy and resell. -
Ford Credit. They own the car, not the dealer. -
airbag warning light stays on
akirby replied to lpgao's topic in Alarms, Keyless Entry, Locks & Remote Start
Just FYI - the "battery" light doesn't mean the battery is bad it means the charging system (alternator) is not putting out enough voltage to recharge the battery. -
My advice is you generally get what you pay for, but I don't have any direct experience with this stuff.
- 7 replies
- 2015 edge
- 2015 edge sport
(and 4 more)
All that "work" was paid for in the original sale. Ford may also compensate the dealer for the lease turn in work. -
They don't split anything. Each dealer gets commission on the vehicles they sell or lease. -
I think it's safe to assume you can easily get a $30 oil change.
This is why I actually prefer driving my 2.0LEB Fusion over the 3.7 MKX. MKX feels like a dog below 4000 rpm (it's not but it feels that way compared to the instant torque of the 2.0LEB).
Notes from changing Anti-freeze on the 4 cylinder 2.0L Ecoboost
akirby replied to LorenAZ's topic in EcoBoost Mod & Tech
it's probably to get rid of leftover coolant that might be incompatible with the new coolant. Unless you're doing a chemical flush then you need to neutralize those chemicals.- 18 replies
- anti-freeze
- 2.0l ecoboost
Wow - December 2009. Did you get in the wayback machine with Mr. Peabody to find this one?
Thank goodness. I was so worried!
http://www.fordedgeforum.com/topic/12731-radiator-fan-assembly-replacement-procedure/page-2?hl=%2Bradiator+%2Bfan&do=findComment&comment=115147 Could also be the water pump if it loses coolant before it overheats.
Where did you get those prices? $94 for an oil change?
It's a classic case of suppliers exactly matching new car demand (to cut costs and meet mfrs ever tightening cost targets) which makes it hard sometimes to overproduce to make enough repair parts for existing vehicles.
But you said maintenance package not extended warranty. They're completely different.
Doesn't matter how dirty they get - use the same stuff you would use on the rest of the car. Bug and tar remover for tough stuff, car wash soap otherwise. Paint sealant or wax to protect just like paint.
Car wash soap.
Anyone use a hydraulic floor jack to lift their Edge?
akirby replied to ben senise's topic in Wheels & Tires
Ok, guys, knock it off. I edited/deleted some posts. No more personal attacks including moderator insults. Chefduane - KLinNBC appears to be right for the 2015+ Edge and MkX. They do appear to use the pinch weld to lift the vehicle. This is completely different from the pre-2015 models that straddle the pinch weld. You're both right depending on the model year. -
Not usually. There is very little maintenance actually required - probably $50/yr for fluid and filter changes plus a few bucks for wiper blades, etc. Maybe $200 for a transmission fluid swap but that's about all that is really required. Most of the cost ends up being "inspections". So at least understand what you're actually paying for above and beyond the minimum required. Also if you do it yourself you can decide when and where to have the maintenance done.
He apologized for it and to be honest your comments about people not taking the jack out of the car was just as bad. You could have simply said the 2015+ models use a different jack than the pre-2015 models. It's natural for people to assume that newer vehicles work the same as theirs or to simply not notice the year. There is no need to get upset over a simple mistake. -
After looking at the picture in the owner's manual on my MKX it would appear that the CD4 vehicles have reinforced pinch welds that will hold up the vehicle. But I'm also certain that's not the case on the CD3 (07-14) models. -
Let's not exaggerate. It's not built at all by Mazda. The platform was derived from the original Fusion platform which itself was derived from a Mazda platform so they do share parts but it's built and engineered 100% by Ford, not Mazda - although they do share parts.
