Moderator-
Aftermarket Trailer Hitch power wiring route
akirby replied to krazykanuck's topic in Cargo, Hauling, Roof Racks & Towing
I used the 12V power point in the rear cargo area. 2016 MKX. -
akirby replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Ford added security to the web interface so you can't just type in any vin. This dealer has a lookup feature that works. http://mcmahonford.com/Look-Up-Window-Sticker/ -
Grinding noise after brake booster replacement
akirby replied to oldmankirby's topic in Brakes, Chassis & Suspension
It is an appropriate name.... -
ABS Tone Ring Repair - Fault Code C0226/C0222
akirby replied to suprasteve's topic in Brakes, Chassis & Suspension
Topic pinned. Excellent write-up! -
Second gen. Edge - Line item option delete?
akirby replied to Chipster's topic in 2015+ Edge & MKX Generation II
I've had it for 4 years on my Fusion and the only time I've used it is when I accidentally hit the button on the end of the turn signal stalk - it takes me a few seconds to turn it back off. -
Because both heated wheels and rubber mats are frequently used together in colder climates. Look at it this way - they could have left out the mats and just added $200 to the cost of the Edge and you would have bought it without batting an eye. Or if the cost of the heated wheel by itself was the same as the wheel and the mats you wouldn't have cared. Just seems silly to go without a feature you really like based on a $100 set of floor mats either way. -
Knock off the dummy talk. No need for personal attacks. -
Which anemic 4-cylinder are you referring to? The 2.0 is also an EB and it's nowhere close to anemic.
No idea on the brake issue but I like your login name. -
akirby replied to jmr061's topic in Audio, Backup, Navigation & SYNC
Or maybe in automotive terms - PEBSWAS -
So you guys probably understand PEBKAC...... -
Sorry to keep repeating this but there is no SD card with sync 3. Maps are all internal.
That's what I tried to tell you in post 2 - guess I didn't go a good job. IMO they work just fine on auto and I've had them on several different vehicles. If you get a light mist and they don't come on soon enough just bump the stalk to initiate a wipe and they're usually fine after that. Adjust the sensitivity as needed. And please, please, please - RTFM.
I would suspect the phone before sync 3 unless it's doing the same thing on 2 different phones. Try doing a hard reboot on the phone and make sure you have the latest OS update. -
The 3.5L and 3.7L are strong engines but lack that off the line power you get with the ecoboost engines. They do perform better at higher RPM but I find myself flooring the 3.7L in the MKX to get it moving whereas with the EB (even the small 2.0) you get instant torque at low RPM. It all depends on how hard you're used to accelerating. For my wife who hardly ever goes past 50% throttle she'd never notice the difference.
just pour a glass of water on the windshield above the sensor.
You'd have to put it on the outside of the windshield itself which is hard to reach and make sure the wipers don't get you if it does activate. Also not sure just covering it with your hand will actually activate it.
Check the left hand menu options to see if you have the auto wiper option. If you do then make sure it's set to On. You can test it by spraying it with a hose in the driveway.
Slight correction. If you have auto-wipers but you turn them off via the left hand menu, they will operate just like regular intermittent wipers.
Pressing the climate button first is no big deal no matter how you want to spin it. We keep ours on the audio screen so even if it was on the home screen like you can do with Forscan it would be an extra button press. A hard button is obviously the best solution from a consumer standpoint but it's also more costly for Ford to have two different button configurations depending on the option package.
The problem is the engine temp gauge only reports the coolant temperature, not the temperature of the cylinder walls.
On second thought not a good idea. Even without coolant circulating the coolant in the block absorbs the heat from the engine. Without it the engine would get very hot almost instantly. Maybe using water instead of coolant and changing the oil frequently would help.
That is an interesting scenario. I'm sure it won't overheat within a 1/4 mile but I'm not sure if a total lack of coolant would affect anything else internal to the engine. Obviously the water pump doesn't matter. If you decide to do that I'd recommend testing it in the driveway idling first.
