    343
1 Follower
About akirby
17,119 profile views
  1. Your Edge was built in Canada not the U.S…….. 😎 It probably means they don’t plan to do any more updates since they switched to the new Google based system. They almost never did any functional changes anyway so of your sync 4 is working fine then this really is no change.
  2. That’s not his point at all. The point was the only way to properly test it is to compare Cold Cranking Amps with the new rating, so if you never heard of CCA then there was a good chance they didn’t test that. It was not an insult.
  3. If it’s the original battery I guarantee it’s bad. They rarely last more than 3.5 years. They seem ok u til they die completely. Either replace it or have the CCAs measured.
  4. You must have hit quote on your first post so it included your first post like I did here. 1004ron deleted it. To add a new message just go to the bottom of the page,
  5. It depends on whether the engine software is designed to take advantage of higher octane by advancing the timing. Thats where the extra power comes from - has nothing to do with the fuel per se.
  6. Ford authority reporting Escape goes away late next year. Presumably to make way for the new low cost EVs. Maybe they’ll extend the wheelbase on the Bronco sport and add a fwd street oriented hybrid.
  7. Doubtful. Escape is also on the endangered list.
  8. Auto hold lets you step on the brake in drive then release the brake and the brake will hold until you step on the gas again.
  9. It’s already discontinued. Stopped a few months ago. They're going to add Super Duty production there in 2026.
  10. Play song Hotel California Play artist Eagles Play album Hotel California Or create a playlist and say Play Playlist. Should still work even for burned CDs. Worst case just edit the mp3 tags. Works great.
  11. Oh no - what broke on your engine? 😂 seriously though - Our 22 Nautilus does it in D mode. Are you riding the brake?
