Thanks for the compliment!
I did not have to jack up the vehicle to open the wheel well. There's actually 3 hex screws (7/32" IIRC) or 5.5mm.
I honestly feel that only those 3 would be require to work in this area. BUT since it is so easy to remove the bumper cover, I would pull the whole thing and work on it in my living room or something.
What I did was lay a utility blanket down and pulled off the Bumper Cover and lay it on it's face.
Steps to remove front bumper:
open hood
unscrew 4 plastic screws and remove the 4 anchors ( you'll see what I mean )
loosen the 2 hex screws in front of the anchors (don't remove them)
unscrew and remove the 7/32" fender screws in the wheel well (3 each side)
Look inside the well and locate the screws that are upside down holding the bottom of the bumper cover to the car. (6-8 or so?)
On each side, locate above the wheel well, the area where the fender meets the bumper cover.
Put your fingers inside on the bumper cover and pull it back until it unclips from the fender (it will pop slightly and you might be apprehensive at first. But if made sure to get all the screws, nothing should break.
Also unclip the pigtail for the light bars on both sides.
After you have done both sides and have laid down utility blanket or cardboard, remove the last 2 screws that you loosened in the 3rd step.
At this point, you should be able to lift the whole face off and lay it down. Be careful, as it will have a tendency to fall on its face if just stood up.
Here's the instructions I used. It was for a 07-10 model, but everything is essentially the same:
http://mechanixtrix.com/Article/Article.aspx?ArticleId=405
