idunno
Everything posted by idunno
  1. I have a new 2013 Ford Edge SEL AWD equipped with MyFordTouch. I cannot get the extra standard SecuriLock key I purchased from Ford Dealership to start the car. I am following the instructions on p 81 in the 2013 Owners Guide. I have the two original integrated keyhead Transmitters keys which are stamped SA on the key blade. The extra key is also stamped SA . The service tech at dealership said the programming of keys no longer works in the Edges but I bought the key anyway just to give it a try because I like having the extra "cheaper" key to keep as a spare. Has anyone here successfully programmed a 2013 Ford Edge or other 2013 Ford using the documented procedure? If so, please provide any suggestions. Here are the instructions I am following. Do I need to look at any lights/info on the dash to determine if I am doing something wrong? Programming a Spare Integrated Keyhead Transmitter Note: A maximum of eight coded keys can be programmed to your vehicle. Only four of these eight can be integrated keyhead transmitters. You can program your own integrated keyhead transmitters or standard SecuriLock_ coded keys to your vehicle. This procedure will program both the engine immobilizer key code and the remote entry portion of the remote control to your vehicle. Only use integrated keyhead transmitters or standard SecuriLock_ keys. You must have two previously programmed coded keys and the new unprogrammed key readily accessible. See your authorized dealer to have the spare key programmed if two previously programmed coded keys are not available. Read and understand the entire procedure before you begin. 1. Insert the first previously programmed coded key into the ignition. 2. Turn the ignition from off to on. Keep the ignition on for at least three seconds, but no more than 10 seconds. 3. Turn the ignition off and remove the first coded key from the ignition. 4. After three seconds but within 10 seconds of turning the ignition off, insert the second previously coded key into the ignition. 5. Turn the ignition from off to on. Keep the ignition on for at least three seconds, but no more than 10 seconds. 6. Turn the ignition off and remove the second previously programmed coded key from the ignition. 7. After three seconds but within 20 seconds of turning the ignition off and removing the previously programmed coded key, insert the new unprogrammed key into the ignition. 8. Turn the ignition from off to on. Keep the ignition on for at least six seconds. 9. Remove the newly programmed coded key from the ignition. The key will start the vehicle’s engine and will operate the remote entry system (if the new key is an integrated keyhead transmitter) if it has been successfully programmed. Wait 20 seconds and repeat Steps 1 through 8 if the key was not successfully programmed. Take your vehicle to your authorized dealer to have the new key programmed if you are still unsuccessful. Wait 20 seconds and then repeat this procedure from Step 1 to program an additional key.
