sabasigh
About sabasigh
sabasigh's Achievements
  1. Thanks but i have All Access. Ok i looked at the channel lineup carefully and anything above like 220 was online only.
  2. I tried searching but the only post i found was bout refreshing my radio. I have a 2011 Edge w/MFT on the latest Sync version. I just subscribed to Sirius since my SD card is probably still indexing as i type this. Anyway, my Sirius tuner only goes up to like channel 223? I sent a refresh signal a few times and still nothing above that. Is that a limit of the radio? I'm on the premium Sirius package. TIA.
  3. Constant media indexing of the SD card makes it useless for commands. Every time i get in the car start it up and switch to SD...index is lost. This has been a nagging issues on various versions...really no excuse this function shouldn't work without these types of issues.
  4. Issues persist, constant media indexing...and now when i'm in a source OTHER than BT and i initiate a Siri command...it plays over MFT which is fine, but then the source changes and stays on BT.
  5. Thanks, did the master reset on my lunch break and on the drive home it was flaky. I disconnected the battery later this evening for a few mins. Will see how it does but i'm not particularly hopeful.
  6. Ditto same problems since the update. Would a Master reset from the menu suffice or do i need to pull the battery cable?
  7. http://www.engadget.com/2015/12/03/ford-sync-siri-eyes-free/ Starting today, owners of a Ford vehicle purchased in 2011 or later can download a new software update that will add Siri functionality to their SYNC interface.
  8. When replacing the rear pads just due to wear/mileage...did you have the rotors turned?
  9. Thanks for making these. I have the 2011 model and look forward to your videos.
  10. Considering all the issues MFT had at release and the pains to get something stableā€¦ Is anyone really brave enough to jump on SYNC 3 immediately?
  11. I never use CD's anymore so i use this: http://www.amazon.com/Mountek-nGroove-Universal-Phones-Devices/dp/B004G1L52Q/ref=sr_1_1?s=wireless&ie=UTF8&qid=1427606082&sr=1-1&keywords=mountek
  12. pretty good interview with Connected Vehicle and Services Executive Director Don Butler at: http://www.engadget.com/2015/01/14/ford-sync-3-applink-3.0-navigation/ Tiny blurb on "continue to upgrade Sync Gen 2 and MFT" at about 6:35 in. Take it for what it's worth...which ain't much, lol
  13. Anyone running these rims on their 2011+ Edge? I really like these but they aint cheap either. Would they require a spacer? I read the newer Explorer 20's do. [Edit] my bad: http://www.fordedgeforum.com/topic/8406-20-taurus-sho-wheels/
