viper001
About viper001
viper001's Achievements
MFT Overhaul Press Release
viper001 replied to phantom9000's topic in Audio, Backup, Navigation & SYNC
My experience has been that 2.11 has been much more stable than 2.8 was, but neither has been great by any stretch of the imagination. I see my system spontaneously reboot about once a month or so, but it usually recovers OK after that. I have also noticed that if I am using the navigation and I arrive at my destination, if I leave that little pop-up window on the system (the one that tells you have arrived and what your travel time was), and then I shut the car off without pressing "OK" on that window that the system will not seemingly shutdown like it is supposed to. I don't know if the screen is staying on all night, but when I start the car up the next morning instead of getting the Ford splash screen and the normal boot-up it will instantly come back on with the previously described screen from the day before. I have also noticed that the more I push the system the more I can get it to crash and burn. Which means unfortunately the times that it fails are the times that you are depending on it the most. The only time I've had a completely black screen that required the fuse pull was in the middle of our family vacation while stopped at a New York rest area. Luckily I knew the fuse trick or we would have been a little screwed as we were depending on the navigation at that point. I received a phone call from Ford the other day but I missed the lady both times she called me. I called her back but never got a return call. I wonder if that was my opportunity to be offered a comp and I missed out? In any event I am content at this point to wait a couple of more months and see what the update looks like. To have taken this much time to get it to us would imply that it would be thoroughly tested, but I guess we will have to see that for ourselves. -
For the record (if Ford is reading this forum) I would be happy with $1000 and a big reassuring hug for my problems. Sans the hug I'd be looking for about $1200... :D -
So it's available now if you want to download it?? -
All I know is before I went to 2.11 mine would automatically adjust the clock for DST changes. Plus, if it can't do that how would "Auto Time Zone Change" ever work?
I'm on 2.11 and mine also did not change automatically. Can I ask what your time setting are, maybe we all have it programmed wrong? Right now I have GPS time sync set to on, DST set to on, and Auto Time Zone set to on. it doesn't make sense, with GPS sync turned on the DST one technically shouldn't matter, it should just download the correct time from the sats, right?
http://www.foxnews.com/leisure/2011/11/07/ford-bows-to-pressure-revamps-highly-criticized-infotainment-system/?test=faces
I just hit 11k and I still have life left on the oil according to the computer. And I know it hasn't been reset as I check it periodically and it moves down really slowly. Where does it say you shouldn't go over 10k, and if that is the case why wouldn't the computer recommend a change accordingly? All my previous vehicles I have changed at least every 5k but I thought for once I would give this monitoring thing a try, now I'm wondering if I have messed up by running it too long... Ok, it just occured to me I could look this up myself. Here is what the owner's manual says about the oil change interval: NORMAL SCHEDULED MAINTENANCE AND LOG For your convenience, your vehicle is equipped with a message center which determines the proper oil change service interval. You should perform the engine oil change as indicated by the message center. The message center will display ENGINE OIL CHANGE SOON or OIL CHANGE REQUIRED to indicate when an oil change is needed. The engine oil change service needs to be completed within two weeks or 500 miles (800 km) after the OIL CHANGE REQUIRED message is displayed. Your oil change service interval can be up to one year or 10,000 miles (16,000 km). Reset your Intelligent Oil Life Monitorâ„¢ after each engine oil and filter change; refer to the Instrument Cluster chapter. If your message center is prematurely reset or becomes inoperative, you should perform the oil change interval at six months or 5,000 miles (8,000 km) from your last oil change. So from that I am reading that as long as you don't go over a year, you could potentially exceed 10k miles before an oil change. Or am I reading it wrong?
I'm just curious, I know it has already been discussed that there are currently no updates for the SD-based navigation data that came with my Touch based navigation system. But, has Ford ever offered updated map and POI data for any of their built in navigation systems? I am assuming that 2011 when I bought my car was not the first time Ford has offered such a system, but in all the forums and threads I've seen I have never actually heard of anyone saying they had received (or bought) such a thing, even on an earlier model vehicle. My other vehicle is a Honda minivan, there tends to be crapping and complaining over there due to the high costs of the updated DVD disks, but Honda is pretty good about at least offering updates once a year.
Don't have all the Sirius channels
viper001 replied to wlepse's topic in Audio, Backup, Navigation & SYNC
Browse also locks up my system as well, and I'm running 2.11. Since I have dropped the Sirius audio portion on my account it is no longer and issue though. -
Sirius quality not woth the money...
viper001 replied to Victor Wolansky's topic in Audio, Backup, Navigation & SYNC
What did they reactivate for that price? I just got the traffic and Travellink stuff turned back on for $20 for 5 months (no audio) and I thought I was doing pretty well. If you got everything turned on in two vehicles for the same I will have to negotiate a little bit harder next time. :-) -
Glad you mentioned that the $24 didn't include the traffic as I would like to have both the traffic and the travelink if they will do it cheaply enough. So far they have quoted me $69 for a year of just those two things which I turned down. My next step is to see if they will still do the $77 deal for everything, if not I will hammer on them for a better price for everything but the audio portion. -
So my free trial expired and they turned me off, pretty much exactly on the minute that they could. I have already called them once in the car to get their initial offer, they started off at +$300 for everything for a year, then they came down to $250 for everything for a year, and then they offered me $69 a year for just the Traffic and Travelink stuff. I am leaning toward not going with the audio since I honestly only use that on trips, and I don't really take enough trip to justify the expense. So what is the best price anyone has gotten on everything for a year, and what is the best price for just the Traffic/Travelink portion? I saw someone posted they got the latter for $24 which I would do, just wondering what is the best on the whole bundle. Thanks in advance! -
2011 Edge/MKX My Touch and Sync Problems
viper001 replied to akirby's topic in Audio, Backup, Navigation & SYNC
Ok, I'm glad someone else has noticed this as well. Most times I get in my car the A/C kicks on and blows like crazy (temps here have been in the 90's for much of the summer and I leave my car closed up so it's really hot). But occasionally I will get it and it is barely blowing even though the cabin is probably +100 degrees. I also have to fiddle with increasing the fan and then it seems better. I have noticed that for whatever reason it seems to happen more often when I have a car full of people getting in but I have no idea what that would have to do with anything. It's probably coincidental... -
Rear seat won't fold down
viper001 replied to edgedriver79's topic in Interior, A.C., Heat, Interior Trim
When I took delivery of my 2011 Edge that rear seat would not latch at all in the upright position. They discovered the problem while they were prepping my car for delivery. They engaged a Ford engineer and eventually decided the entire bottom part of the seat needed to be replaced. It was pretty pricy, but obviously covered under warranty for me. Good luck. For the record the seatbelt latch in that position on my car would not engage. I am guessing the guy doing assembly that day must have been having a bad day or something to not notice either thing. :-( -
So yesterday on one of my trips my phone would not connect to SYNC at all. When I tried to force SYNC to connect it popped up and told me "Bluetooth is not turned on, would I like to turn it on?" to which I said Yes. Still would not connect. When I got to my destination and restarted the car I had a black screen momentarily, and then I got the infamous "Performing scheduled maintenance" reboot screen. When that finished my phone was connected and I had no further problems. For the record my phone is a crappy Nokia flip that is a couple of years old, nothing fancy. Overall I haven't had much problems with getting it to pair with SYNC.
