ebank
Everything posted by ebank
I've had the 4g modem go offline a couple of times. I used Forscan to reset the module and it came back online.
From https://media.ford.com/content/dam/fordmedia/North America/US/2015_Specs/2015_Edge_Specs.pdf Fuel delivery Sequential multiport fuel injection The 2.7l and the 2.0' had Direct injection.
I don't charge my phone at home during the week. My 40 minute commute charges my S23 (previously Fold4, both large screens and heavily used) to 100% plugged in to the Cubby USB ports using android auto. Waze is active the whole commute time. On the weekends i usually forget to charge my phone because of this effective weekday charging. So I would think that there is definitely something wrong with the USB ports on the subject Vehicle.
Headlight Switch conversion to automatic
ebank replied to D-Weezy's topic in Accessories & Modifications
A quick google search came up with this: https://www.amazon.com/Universal-Automatic-Headlight-Control-Modification/dp/B07YSFY8ZJ YMMV -
After 18 months of ownership, I'm still not brave enough to try the self parking feature.
Windshield wiper brakes failing
ebank replied to enigma-2's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Absolutely fabulous tutorial! I plan to do the wiper brake upgrade on mine next weekend. I had the same problem locating a longer dipstick - I ended up pulling one from a junkyard.- 1 reply
- 2
Remote Start Stopped working
ebank replied to Rob4652's topic in Alarms, Keyless Entry, Locks & Remote Start
How old is the car battery and what is the tested CCA vs rated CCA? A battery that looks like it has the right voltage may still be going bad. These vehicles are very sensitive to problems presented by an old or failing car battery. -
'19 ST's are the best ST's ? Welcome to the ride.
This issue sounds very similar to the behavior my 2011 exhibited when the brake booster failed. In 2011 there was a recall on the booster, but i'm not sure about the 2010.
I think the solution I remember most folks using is the #3 memory for the reverse mirror position.
Blue St's are the best! ?
Howdy Neighbor!
2007 Edge with ODO error again and no trans issues
ebank replied to Good_T's topic in 2007 Edge & MKX
First thing I would check is the battery, not the voltage, get an accurate CCA test. Replace the battery if it is lower than rated CCA. -
Have you tried to adjust the volume with the audio volume knob while the chime is going off? The only way I found to adjust the navigation voice prompts is while the voice is active. So, um ya, I am not advocating that you go over speed limit and try adjusting the volume with the audio knob, but there it is. ? I don't think we have that speed limit alert in the States.
Towing Capacity on 2016 2.7l
ebank replied to FatalScroll's topic in Cargo, Hauling, Roof Racks & Towing
It looks to me like the 2016 and 2017 2.7l Sport did not have an option for a towing package so the only option is aftermarket. When means no upgraded radiator or oil cooler. Maybe that could be the reason for the lower towing capacity. A normally aspirated engine like the 3.5L produces less heat at sustained higher horsepower delivery then a forced induction (turbo) 2.7l engine. They used to say: There is no replacement for cubic inch displacement -
When I had my 2011, a number times when the remote start would not work, I tried using the remote start while sitting in the car. This cleared up the remote start and no key found problems for me
1. No, it can be anywhere in the car. Start with checking the battery in the remote. 2. The proper sequence is lock-start-start, lock once, start 2 times. 3. I would say no.
The ST-Line has almost everything an ST has in the U.S. except the 2.7l ecoboost i think. I found This: https://www.caranddriver.com/reviews/a39108471/2021-ford-edge-st-line-by-the-numbers/
2011 Ford Edge SEL APIM failure
ebank replied to ColinM31's topic in Audio, Backup, Navigation & SYNC
Recent Similar issue:
