ebank
    4
About ebank
2,611 profile views
ebank's Achievements
  1. I like and use the feature often. Recently I was helping to load a friends Highlander which doesn't have that option - I realized how much I admire having the hands free option.
  2. This app and a appropriate OBDII scanner should be able to help you monitor your transmission temps, https://apps.apple.com/us/app/torque-car-pro-obd2-scanner/id1665043651 I use the app on android so YMMV.
  3. I've had the 4g modem go offline a couple of times. I used Forscan to reset the module and it came back online.
  4. From https://media.ford.com/content/dam/fordmedia/North America/US/2015_Specs/2015_Edge_Specs.pdf Fuel delivery Sequential multiport fuel injection The 2.7l and the 2.0' had Direct injection.
  5. I don't charge my phone at home during the week. My 40 minute commute charges my S23 (previously Fold4, both large screens and heavily used) to 100% plugged in to the Cubby USB ports using android auto. Waze is active the whole commute time. On the weekends i usually forget to charge my phone because of this effective weekday charging. So I would think that there is definitely something wrong with the USB ports on the subject Vehicle.
  6. A quick google search came up with this: https://www.amazon.com/Universal-Automatic-Headlight-Control-Modification/dp/B07YSFY8ZJ YMMV
  7. After 18 months of ownership, I'm still not brave enough to try the self parking feature.
  8. Absolutely fabulous tutorial! I plan to do the wiper brake upgrade on mine next weekend. I had the same problem locating a longer dipstick - I ended up pulling one from a junkyard.
  9. I Know this won't help the original poster, but if you have a 2015 or newer i recommend getting one of these armrest covers: https://www.amazon.com/gp/product/B0948KYZBX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 I put one (proactively) on my '19 and if works great.
  10. How old is the car battery and what is the tested CCA vs rated CCA? A battery that looks like it has the right voltage may still be going bad. These vehicles are very sensitive to problems presented by an old or failing car battery.
  11. '19 ST's are the best ST's ? Welcome to the ride.
  12. This issue sounds very similar to the behavior my 2011 exhibited when the brake booster failed. In 2011 there was a recall on the booster, but i'm not sure about the 2010.
  13. I think the solution I remember most folks using is the #3 memory for the reverse mirror position.
