speeder
Everything posted by speeder
  1. If you are using the Apple composite video cable, don't plug the USB plug into the ports in the center console. I had the same problem with the cable until I unplugged the USB plug. If you want to supply power to the iPhone, use a USB cigarette lighter adapter. Make sure the car is stopped and parking brake on.
  2. I took mine up to Reno, Lake Tahoe and Yosemite this past memorial day weekend. In all I put about 1000 miles on the trip. I averaged about 20.4 mpg. The Edge has about 1600 miles on it
  3. About 1.5" in the front and 1" in the back. The wheels are 22". No difference in gas mileage. The springs do help. It does seem to tighten up the suspension a little. A set of thicker sway bars would help more if someone would come out with a set.
  4. i just got back from the dealer after having perform the update to 2.8 from 2.4. Right away I can tell that it is much improved over the previous version. Button presses are much more responsive and flipping between different menu options are noticeably faster. Overall I'm quite happy with the update and had not experience any of the problems others had mention. So far everything seems to be functioning but only time will tell.
  5. Congrats on your new Sport! I got mine in the same color as well.
  6. I have used this company many times over the years with excellent results. Wheels America
  7. I notice too that little lip on the front edge of the front door tends to collect water. That is definitely a design flaw. if it's not address soon we would definitely be seeing rusted out doors in a few years. I believe your solution of filling that lip with silicone to prevent water from pooling in that area should work as long as it is not another drain hole for the door.
  8. Unfortunately I didn't take proper "before" picture to show the change in ride height. Here's a picture from a different angle before I lowered it. Look at the gap in the front wheel well. It still may be a bit hard to tell from that angle, but believe me it is noticeable.
  9. I stuck with the stock dampers. I had a local shop install and align it.
  10. The ride quality is a bit firmer but not bone jarring. I've felt that the original ride quality was a bit floaty for my taste. The springs definitely improved the handling of the vehicle. The Edge feels more confident in turns. All in all, a worthwhile mod. You won't be disappointed with results. Now if someone would make a set of sway bars.... :hyper:
  11. I just had a set of Eibach springs installed this afternoon. It dropped the front 1.5" and 1" in the back. What do you think?
  12. It was pricey. It was $1050. I had the entire hood, grill, fender, headlights and bumper covered. I didn't want to see the lines on the body.
  13. I just had my brand new Edge wrapped today. I had them cover the entire front end of the car. The entire job took six hours to complete. Here are a couple picts of the installation:
  14. After placing an order with my dealer and waiting a month and a half, I'm finally picking up my 2011 Edge Sport tomorrow. It's Kona Blue with every option except for the rear DVD entertainment system. I will try to post some pics tomorrow. I can't wait. :hyper:
